Transmission overfilled
Old May 19, 2014 | 08:43 PM
giacomo56's Avatar
giacomo56
Default Transmission overfilled
'05 RK ......I changed all of my fluids today, unfortunately I transposed the fluids amounts and put 32oz in the transmission instead of the required 24oz...any damage caused or possible problems I should look for?
I took my bike for a ride, doesn"t seem to be bother by it.
Old May 19, 2014 | 08:48 PM
jstrenn's Avatar
jstrenn
The excess fluid will vent overboard once you get it hot. Any way to stick a syringe with plastic tubing in the fill hole and suck out 8 oz's?
Old May 19, 2014 | 09:06 PM
dochawken's Avatar
dochawken
Originally Posted by giacomo56
'05 RK ......I changed all of my fluids today, unfortunately I transposed the fluids amounts and put 32oz in the transmission instead of the required 24oz...any damage caused or possible problems I should look for? Look for a quart measuring cup...drain out the excess....no big deal..
drain the excess..
Old May 20, 2014 | 01:07 AM
FLYER's Avatar
FLYER
Turkey baster ought to do it.
Old May 20, 2014 | 04:55 AM
equandt's Avatar
equandt
Turkey baster is how I remove excess fluid. Go get one from Walmart. Don't use your wifes / girlfriends turkey baster. They will get mad at you.
Old May 20, 2014 | 07:22 AM
Razorback's Avatar
Razorback
I've used the pump from a shampoo bottle.
Old May 20, 2014 | 08:47 AM
TWIN CAM 96's Avatar
TWIN CAM 96
If you have one of these it will do it has a measured catch bottle
Mityvac Vacuum Pump - Save on Mityvac Pumps at Harbor Freight!
Old May 20, 2014 | 08:53 AM
ElectraGlideSteve's Avatar
ElectraGlideSteve
Agreed, I keep a pump from an old Windex bottle in my tool box.
Works very well and costs nothing.
Whatever method you use, get the excess out of there.
lennyb3us
Jun 19, 2010 07:03 PM
seoris
May 28, 2010 08:31 PM
dibe
May 14, 2010 08:21 PM
jjr
Jul 23, 2009 02:08 PM
hdjoe88
Nov 16, 2006 10:54 PM
