Big problems!
Old May 26, 2014 | 03:49 PM
xjbx187x's Avatar
xjbx187x
6th Gear
Default Big problems!
Hey guys, I was out for a nice short ride today everything was going great and all of a sudden my bike started making a loud squealing noise and my rear tire locked up on me. So I get to the side of the road thought it was the rear brakes but they are fine. So I put it in neutral and go to start it and it jumps just like if you were starting it in gear without pulling the clutch weird right. I pull the clutch in kick it into 1st and go to get back on the road but it's like I'm holding the brakes it won't move after a little more trying it starts to move then stops and makes a huge clunking noise. Enough to freak me out and keep from trying that again so I'm lost any ideas as to what the issue could be. It's a 1999 FLHTC TC/88 with 9,000 miles on it.
Thanks, James
Old May 26, 2014 | 03:56 PM
jus2anoyu's Avatar
jus2anoyu
Just off the hip here, did the 10k service just get done and someone forgot to put oil in the primary?
Old May 26, 2014 | 04:04 PM
SR90's Avatar
SR90
Drive pully bolts... Are they backing out and hitting the swingarm? How do you only have 9000 miles on a '99?
Old May 26, 2014 | 04:12 PM
JustaHawg's Avatar
JustaHawg
Old May 26, 2014 | 04:17 PM
danzio's Avatar
danzio
Sounds like a catastrophic transmission failure. Hope not!
Old May 26, 2014 | 04:22 PM
xjbx187x's Avatar
xjbx187x
6th Gear
I just changed all the fluids myself there's definitely fluid in the primary and I bought it a year ago with 3000 miles on it
Old May 26, 2014 | 04:23 PM
SpiderPig's Avatar
SpiderPig
I am second the drive pulley bolts.
https://www.hdforums.com/forum/touri...osened-up.html
Old May 26, 2014 | 04:27 PM
jus2anoyu's Avatar
jus2anoyu
Drive pulley bolts wouldn't keep it from starting in neutral. Gotta be in the primary.
Old May 26, 2014 | 04:37 PM
hardheaded's Avatar
hardheaded
clutch hub broken is my guess or bad bearing in it.
Old May 26, 2014 | 05:39 PM
Bowhunter61's Avatar
Bowhunter61
