95 Ultra mini apes
Old May 27, 2014 | 02:09 PM
xknucksx's Avatar
xknucksx
Default 95 Ultra mini apes
So I've read endlessly about being able to put 10" minis on a bagger with keeping stock wires and cables, however every bike seems to be newer. I need to know if the older bikes have the same luxury. Anyone with a pre 96 that can chime in here?
Old May 27, 2014 | 10:31 PM
xknucksx's Avatar
xknucksx
Bump, anyone?
Old May 28, 2014 | 11:23 AM
xknucksx's Avatar
xknucksx
I know someone has apes on an older ultra!
Old May 28, 2014 | 01:00 PM
BIGRED1's Avatar
BIGRED1
I have a 95 and I was able to put a taller bar (and it wasn't much) on but at the time there was only one available.
The reason; the front forks use the handlebars as an air reservoir. If you can make a reservoir to mount somewhere else then, you should be able to put just about anything you want.
Another possibility would to put cartridges in the front forks eliminating the pneumatic set-up. The only problem there is that you would loose the anti-dive function.
It might help if you were to look at the manual for the Ultra from that era.
sdevine49
Aug 3, 2011 07:53 PM
cray49a
Feb 5, 2009 01:33 PM
HilllBillly
May 14, 2008 05:50 AM
newby
Dec 5, 2007 03:38 PM
baltimorebook
Nov 9, 2007 03:27 AM
