How do you know when it's time for brake pads?
Old May 28, 2014 | 02:06 PM
Nute's Avatar
Nute
If your bike is 09 or newer the two bolts holding the calipers onto the bike are 10 mm metric. A 12 pt 10 mm socket is required to remove and replace them. Anything will more than likely damage the heads rendering them NFG. Doesn't hurt to clean out the calipers when you have the pads out with a spray can of pad cleaner. Make sure to spay around the area of the pistons. Also smear some axle or brake caliper grease on the pin and where pistons contact back of pads. Make sure not to get any grease on the pads though.
rodney123456
Oct 22, 2015 10:24 AM
nicsvert
Mar 7, 2013 08:54 AM
WdGldDave
Mar 16, 2012 11:06 PM
hdman6
Feb 29, 2012 12:04 AM
jokr
Feb 3, 2008 06:10 PM
