Limp mode again! Dealer tech says replace the twist grip throttle sensor.
Old May 28, 2014 | 07:41 AM
kjkustoms's Avatar
kjkustoms
Default Limp mode again! Dealer tech says replace the twist grip throttle sensor.
My 08 FLHX has gone into limp mode yet again. It went out on the highway at about 55mph, this time the rmps dropped to 1000 and there was NO throttle response, with the bike still running I could twist the throttle as much as I wanted and nothing would would happen. I have tried the usual, disconnected the plug at the throttle body, cleaned it with electrical contact spray, let it dry and applied dielectric grease, cleared the error code. Is the twist grip sensor the next step? Any feedback would be much appreciated befor I drop $200 on the new twist grip. Thanks.
Old May 28, 2014 | 07:54 AM
Proaction14's Avatar
Proaction14
Depends, could be corrosion on the pins, faulty TBW sensor or twisty. This JUST happened to my bike last week. Replaced the twisty as per the error code and the service light cleared and it runs great again. Yeah, its not fun when you roll the throttle and nothing happens. I am not a fan of the TBW, but what are you gonna do.
Old May 28, 2014 | 08:38 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Unplug the ECM, and clean the contacts.
Old May 28, 2014 | 09:34 AM
dawg's Avatar
dawg
Or follow the service bulletin and replace the contacts. Of course your dealer tech should already be doing that if they are servicing it.
Old May 28, 2014 | 09:37 AM
dyna07custom's Avatar
dyna07custom
2008 had a lot of t/s problems as dawg says follow bulletin or replace
Old May 28, 2014 | 09:40 AM
troop's Avatar
troop
Last week my bike just up and quit. Restarted about a minute later w/out issue. It never went into limp mode. A tech at work checked for codes and found a P1511 (throttle control actuator). Per a TSB, I have the new pins/connectors on order and will try that first. If no go, then the twist sensor....
Old May 28, 2014 | 09:53 AM
my67pnycar's Avatar
my67pnycar
Mine went thru that when it was new. After they replaced the twist grip sensor, it ended up being the pins. They lengthened the harness and replaced the pins with the gold plated ones, not a problem since (knocking on wood,lol)
Old May 28, 2014 | 10:00 AM
dfowler1's Avatar
dfowler1
I bought one on ebay for $20 new takeoff. Worked great!
Old May 28, 2014 | 11:29 PM
hover's Avatar
hover
Same problem here, dealer knows nothing about the service bulletins or gold pins. No corrosion on pins, but pushing the wire and connector deeper into throttle body connector seems to have helped, so keeping my fingers crossed.
Old May 29, 2014 | 07:23 AM
PROVIDER7's Avatar
PROVIDER7
Can someone post the link to the service bulletin.
Thanks in Advance
