Stumble/miss
Old May 28, 2014 | 09:02 AM
jphillips's Avatar
jphillips
Default Stumble/miss
I've seem to develop a stumble/miss when taking off from stop lights, I've changed plugs, maps n checked battery wires and air filter any ideas would be appreciated thanks
Old May 28, 2014 | 09:21 AM
1Canuck's Avatar
1Canuck
let me be the first to suggest that you provide more information such as what bike, what mods, what maps/tuner. what changed.
Old May 28, 2014 | 06:31 PM
jphillips's Avatar
jphillips
Oh sorry I got a 2011 ultra tc96 with a se255, micro tuner,stock decatted 2-1-2 and s&s air cleaner, I got it cammed in April n this stumble just started last week, I had the clutch adjusted two weeks ago would that possibly cause this? It's the only real thing I can think if that changed
Old May 28, 2014 | 06:39 PM
checkers's Avatar
checkers
Before you do anything, if plugs are not stock plugs, replace with stock plugs and wires. Clean and tighten battery cable ends and ride it. If issue still there: was fluid changed at clutch adjustment? Was correct fluid installed in primary. Yes clutch slippage can feel like a stumble from a stop.
Old May 28, 2014 | 06:47 PM
jphillips's Avatar
jphillips
I put in stock champion plugs, checked battery cables n I put in 1 quart of mobil1 vtwin 20w50 in the primary, the guy that adjusted the clutch is gonna look at it tomorrow so will see n thanks for the response
Old May 28, 2014 | 07:52 PM
1Canuck's Avatar
1Canuck
getting the cam in April required removal of the exhaust. check for exhaust leak
tacohead
Feb 22, 2018 06:51 PM
glsec507
Nov 2, 2017 10:48 AM
jh1328
Oct 14, 2013 03:31 AM
Theo
19
May 31, 2009 10:40 PM
imboden
Shovelhead
28
Oct 10, 2006 10:44 PM
