Turn Signal Module Location
Old 05-29-2014, 02:03 PM
Guy in PEI's Avatar
Guy in PEI
Guy in PEI is offline
5th Gear
Default Turn Signal Module Location
1999 Electra Glide Ultra left side signal lights front and back are dim when bike is idling and don't work at all when bike is running, bulbs seem fine no obvious shorts, different forums and posts seem to say probably turn signal module. Looked at shop manual and see picture of where it is located but can't find it on my bike, pic shows it just below where the tab of the seat goes and I can see the mounting hole but no module. Anyone ever hear of this? Just looking for some ideas before I go to dealership.
Old 05-29-2014, 02:12 PM
69cj's Avatar
69cj
69cj is offline
If the right side is working just turn them on and go to the relay that is clicking. Same relay runs both sides.
Old 05-29-2014, 02:23 PM
Guy in PEI's Avatar
Guy in PEI
5th Gear
There is no clicking sound at all when signals are flashing
Old 05-29-2014, 02:28 PM
69cj's Avatar
69cj
69cj is offline
Ya got me then. I can clearly hear the relay on my 07 when the flashers are on.
Old 05-29-2014, 02:40 PM
Guy in PEI's Avatar
Guy in PEI
5th Gear
Ya it's got me baffled as well, I even double checked the VIN to make sure the model year was right.
Old 05-29-2014, 05:06 PM
$tonecold's Avatar
$tonecold
$tonecold is online now
Received 1,755 Likes on 941 Posts
Just went through this on a friends bike. It is just below the radio inside the fairing. The early models had separate turn signal modules and bank angle switches so it made no difference if the TSM was not mounted firmly and level on the frame. That is where you will find it.
Old 05-29-2014, 05:54 PM
Guy in PEI's Avatar
Guy in PEI
5th Gear
So I should be able to take the outer fairing off and have access to it?
Old 05-29-2014, 05:58 PM
69cj's Avatar
69cj
69cj is offline
It's nice to know that the shop manual is accurate.
Old 05-29-2014, 06:30 PM
$tonecold's Avatar
$tonecold
Yes when you pull the outer fairing you will have access to it.
Old 06-05-2014, 06:57 PM
Guy in PEI's Avatar
Guy in PEI
5th Gear
Yup, took fairing off and there it was thanks for the info. Got a new one from dealer installed tonight and signal lights now working and ready to ride...and that's the bottom line..cause $tonecold said so!!!
adlm
01-08-2017 04:07 PM
phillyrube
11-13-2014 03:42 PM
larsfum
EVO
01-12-2011 11:02 AM
z28kilr
04-14-2010 11:53 AM
Manish_Hawg
11-04-2007 08:59 AM
Quick Reply: Turn Signal Module Location
