Time for new pipes
When I got home I found what I suspected, the stock pipes cracked at the Y pipe coming from the rear cylinder.
I had been toying around with installing Vance and Hines True Duals, since I have the Ovals already and am very happy with the quality. I looked at Fulsac and I think I'd rather yankall the old pipes and start new.
Anyway, I'm leaning towards getting the duals this week. The only thing holding me back is a concern I may lose some low end torque, which is very important to me, seeing how I ride 2 up most of the time AND I drive like a teen-ager from zero to 55 then I turn into a geezer again.
Cost is another factor, since I already have the Ovals, I'd rather not go with a complete exhaust system to the tune of $600-$800 bucks. I also don't care too much for the sound of the 2 into 1 systems, although I am tempted by the numbers they generate.
My build is a stock TC88 with a Stage 1 (SE AC, K&N Airfilter, V&H Ovals and PCIII) on a 2005 Road King Classic with 20,000 miles.
I would love any and all input from those who have this set up, particularly any pre and post install HP and Torque numbers.
Thanks for any help you may be able to give.
I bought my Super Trapps for under $400.00 from my local Harley dealer on sale. I chose to buy local in case their was a quality issue and I needed to return for any reason.
I spoke to V&H some weeks ago as I was contemplating the true duals. They admitted a small drop in HP & TQ. It's a question of looks vs nominal performance drop. You will also have to do another dyno to do it right. I am staying with the factoryheaders but got the HD full length exhaust shield as I hate that gap by the right floorboard. I went with with the Ovals & got them thru Eastern Performance (sponsor on this forum). Price & service A-1! Speak to John.
Stay safe.
Here is a link where several 2-1 and 2-2 pipes were tested on a 95" build. Drop down to post 12 and 13. https://www.hdforums.com/m_546476/tm.htm. I put these in order of torque numbers. Thunderheader and Bassani out performed the Supertrapp. Not by a lot, but enough. It also depends on which number you are comparing, torque or HP. For torque Thunderheader 2-1 were king, and for horsepower the Bassani 2-2 outperformed everything. All of the numbers are subjective. Two different people can get very different numbers from the same pipes depending on the controller they chose, the air cleaner (ness, SE, force whider, etc), even the dyno used.
These are maxnumbers, so not sure about the area where theusable power is, but these numbers show that you can get the same performance from 2-1s or 2-2s, with the proper pipes and tuning.I researched several months before going with the V&H true duals, and I already had theSE II slipons. Idid not lose any noticeable power, in fact the acceleration is a lotbetter and theysoundgreat with the balanced exhaust note. I used the PCIII for a while until they upgraded me to the 25 degree injectors and the race version of the HD 25 degree map download. Haven't needed the PCIII since. The PCIII may fine tune it, but gas mileage and performance are great so noneed toadd it back for now.
Additionally, the Duals eliminated the nasty heat of the crossover and look better. I ride two-up a lot with the wife and only have the true dual pipes w/ SEII slip-ons, SE air cleaner, and map and do not have any problems on any size hill, acceleration from stop or passing, or speed (105+ with no problems). So no need to waste money for more cubic inches when it does all that I need it to do, besides the max speed limit on any road here is 70mph.
or you can get a set of vh td for under $350.00
i like and have tried the vh td with python so but i now have the rh td and really like them
get what you really want the first time not like me
good luck
shawn
