Auxillary Lights -Adjusting ?
Old Apr 1, 2007 | 09:40 PM
Bor's Avatar
Bor
Stage IV
Default Auxillary Lights -Adjusting ?
I just installed the custom auxillary light kit on my 07 SG. Is there anyway to adjust these lights up and down or do you just get what you get? I didn't see anything in the Harley instructions and they lights only look like they adjust from left to right.....
I wanted to say thanks to everyone in this forum! As stated before, the instructions leave a lot to be desired, but with some of the other posts about this topic my dad and I were able to tackle this job and save some money.
Old Apr 2, 2007 | 12:59 AM
MDMYMD's Avatar
MDMYMD
Default RE: Auxillary Lights -Adjusting ?
I would like to know as well about the verticle adjustment.
Old Apr 2, 2007 | 02:00 AM
texas tom's Avatar
texas tom
On my heritage in the manual it stated "using a towel or some similiar covering grasp the lamp carefully as not to break it and bend it to the desired position" In other words there is no vertical adj,the bracket that holds the lamp bends fairly easily and I found it didnt take a lot to make a big difference,not sure if baggers are the same,might check owners manual..
Old Apr 2, 2007 | 02:13 AM
StreetGlider56's Avatar
StreetGlider56
There is minimal vertrical adjustment (bolt loosened) most is side to side...
Carefull bending the custom ones, as you can break the bracket (pot metal)..
Mine lined up ok just needed a small tweak.. Loosened the bolt an it worked out...
[IMG]local://upfiles/11910/4B8FC43A08A44413A365E04829BE701D.jpg[/IMG]
[IMG]local://upfiles/11910/18B3688EC86544FFAE7D0B309FE3D111.jpg[/IMG]
Mickeyyak
Oct 6, 2009 11:35 AM
Mickeyyak
Oct 4, 2009 11:51 AM
krw
Aug 31, 2009 02:11 AM
Borracho
Apr 17, 2008 07:28 PM
Doc Intrepid
Apr 1, 2008 08:40 AM
