Idle..
Old Jun 13, 2014 | 05:15 PM
HDsportster99's Avatar
HDsportster99
Default Idle..
On my 2008 road king, I feel like it idles a bit high. How can I turn this down..?
Noob question lol
Old Jun 13, 2014 | 05:16 PM
hdbob2006's Avatar
hdbob2006
Should idle at 1000 rpm. It's set by the ecm.
Old Jun 13, 2014 | 05:29 PM
Mikula's Avatar
Mikula
like bob said it's a set thing in the computer. need a tuner to do that job. oh the joys of fuel injection
Old Jun 13, 2014 | 06:22 PM
bigskyroadglide's Avatar
bigskyroadglide
On the 08s they had a problem with the tbw. If you cut the engine off at above 1000 rpm then what ever rpm you cut it off at was the startup idle
Take you hand off the throttle next time you cut it off and then cut it off at the switch on the console. If you bike HaS had a chance to warm up and the fast idle speed has been taken care of by the ecm it should be idling around 1000 when you cut it off
This should solve your probkem
Dont rev your engine before you cut it off as well
Old Jun 13, 2014 | 08:50 PM
steelerdude1's Avatar
steelerdude1
There is a reset procedure to get your idle back to normal (950-1000rms) with the kill switch on, cycle the ignition on wait 10 sec, off 10 sec, do that 4 times, it resets the ECM. There is also a download the dealer can do to help, but it does not cure the problem. The only cure is stated above, turning it off with the idle being normal. Use the ign switch not the kill switch.
Old Jun 13, 2014 | 08:55 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
even if u change the ecm for a lower idol u then run the risk of not enough oil flow,and the stator won't put out enough amps to keep up with the load on the battery.
Old Jun 14, 2014 | 07:12 AM
qmann's Avatar
qmann
Exactly why I love my carb! Reach over, adjust...done. Just that quick.
Old Jun 14, 2014 | 11:24 AM
whyrzwaldo's Avatar
whyrzwaldo
I've done the reset procedure as Steelerdude stated in the past. Give it a try. My instructions are: kill switch in run, Ing switch to run for 5 sec, Ing switch to off for 10 sec, do this for 3 cycles, kill switch off, Ing to on, kill switch to run until fuel injector stops and engine light out, fire it up! As others have stated make sure throttle is totally returned before shutting bike down in the future.
Old Jun 20, 2014 | 04:14 AM
HDsportster99
Now I just did stage 1.
Vance and Hines true dual
arlen ness big sucker stage 1
Samson fishtail slip on, with baffle.
Fuelpak
Will this procedure mess with my fuel pak or anything? Bike runs good besides that idles a little high. I contacted V&H on this fuelpak, and they stated the Idle won't be effected by the fuelpak.
Old Jun 20, 2014 | 07:53 AM
FinalShot's Avatar
FinalShot
Fuelpak
You say it idles high... What is the idle speed you are at currently? This might help us....
