I installed Fuel Moto headpipe, dyno tuned mufflers, breather kit, and PCV when I purchased bike in April of 2010! All has been fantastic until I went to wipe some bugs off after last Friday evenings ride! I found my football loose and the pics will show you why!
The upside is I sent an email with pics to fuel moto and early this morning I received a response of We are sorry you are experiencing this but we will be sending out a new filter for you TODAY! No need to return the old one and Thanks for the pics!
Before you fit the new one, check that the cover makes full contact with the outer edge of the filter, if it doesn't then you will need the extra thick gasket from HD and a spacer for the gap you will now have between the center mounting hole and the hole in the cover. One or both of these is likely the cause of the failure.
