Road Glide handle bars and riser bushing vibration
Old Jun 17, 2014 | 07:51 PM
Rollon's Avatar
Rollon
Default Road Glide handle bars and riser bushing vibration
I have put 5" risers on my RG and reach handlebars. With the Drag Specialties riser bushings I have some major vibration at about 2400 rpm. With the stock riser bushings I have vibration in the handlebars from about 2300 to 2800 rpm. Unfortunately, the vibration is bad enough to numb my fingers and hands.
Has anyone tried any other riser bushings? If so, what's the resulting vibration? I see the claim that Alloy Art Gooden Tight GT-2S are the best vibration damping bushings, but anyone can claim that!!! I don't want to keep trying bushings and paying for them.
Your inputs appreciated!
Thanks!
Old Jun 17, 2014 | 09:18 PM
fabrik8r's Avatar
fabrik8r
Thanks!
You can try playing with the torque of the riser bushing bolts, changing the compression of the urethane can change the frequency of the dampening characteristics, you might be able to shift the vibration out of your main cruising range. you might also consider the "vibranators", stupid name but they worked pretty well for me. http://www.vibranator.com/
Old Jun 18, 2014 | 06:10 AM
Rollon's Avatar
Rollon
Thanks for the input. My ride has Throttle by Wire, so the inserts won't work. The torque variation will change the range a bit.
Thanks again for the input.
Mkos1980
Mar 14, 2016 08:20 AM
rsarno
Mar 17, 2012 12:31 PM
WildThang
Nov 17, 2009 10:46 AM
jaysonL
Dec 10, 2008 06:55 PM
jaysonL
Aug 19, 2008 08:25 AM
