Need Cam Advice
Old Jun 19, 2014 | 11:01 PM
Kokes58's Avatar
Kokes58
Default Need Cam Advice
I have an 09 Ultra currently with stock header and 3 1/2" Reinheardts. The motor is currently stock except for the Big Sucker and a Screaming Eagle Race Tuner. I'm considering going with a V&H Power Duals Header and the 3 1/2" Reinheardts. Since I would have to get it tuned again, this would be a good time to change out the stock cams. I need to stay with a Harley brand due to the extended warranty I have. I'm thinking the SE255s but would like to get some thoughts. I do a bit more open road riding than city type riding. I shift for the most part between 3,000 & 3,500 RPMs. Would the 255s give the power in the band I ride or is there another one I should look at.
Thanks
Old Jun 19, 2014 | 11:23 PM
shredder22's Avatar
shredder22
I put the 255's in my 09 RKC and absolutely love them. I have plenty of low end pull for two up riding with the wife and also loaded up with gear. I do not think they are made for high end speed but from 1st to 5th it gives me plenty of giddy-up when needed. I have the stage 1 a/c, V&H Power Duals w/Ovals and PCV 5, this set up works well for me...
Old Jun 19, 2014 | 11:31 PM
dochawken's Avatar
dochawken
Thanks
255's are great cams, several of my riding friends installed them, rave about them...
Old Jun 19, 2014 | 11:57 PM
mgmmgm's Avatar
mgmmgm
TW222 cams FM has a dyno sheet on them.
Old Jun 20, 2014 | 12:38 AM
Lidpro's Avatar
Lidpro
The se255 is a good solid cam at the RPM's your talking about. I put them in my 103 and for two up its great. For solo, its a blast!!
Old Jun 20, 2014 | 01:17 AM
BrownSanta's Avatar
BrownSanta
I have the extended warranty and I went with the TW222's from FuelMoto after talking with Jaime. And my dealer did the work with no issues.
Old Jun 20, 2014 | 05:31 AM
NoCoLoco's Avatar
NoCoLoco
If I were to do a cam upgrade it would be SE255's
Old Jun 20, 2014 | 05:35 AM
Melman's Avatar
Melman
I'm also looking at putting these in my '14 Ultra Limited. I spoke with the dealer and he told me this is their #1 selling cam by far. I need to get a few more miles on the motor and then let the build begin!!
Old Jun 20, 2014 | 06:46 AM
harley7316's Avatar
harley7316
2011 street glide 254E working well here
Old Jun 20, 2014 | 07:42 AM
prezflyr's Avatar
prezflyr
I just put SE255's in my 09 Ultra and wish I had done it sooner. May want to look at the easy start SE255's. My 09 will buck a little when starting sometimes since the 255's were installed but not a real problem.
