Need Cam Advice
Old Jun 20, 2014 | 07:48 AM
NascarGuy's Avatar
NascarGuy
I also run the SE255's in my '09. I do a lot of solo and 2up twisty mountain riding and the torque that the cams produce make them a breeze, a lot less shifting to climb. Also horsepower improvement was noticable but nothing compared to a less torque/more highend cam I would imagine. When I was cam shopping I was more interested in torque and fuel economy than highend horsepower. The SE255 was a perfect fit.
Old Jun 20, 2014 | 09:35 AM
0ldhippie's Avatar
0ldhippie
Too bad ya "have" to stick with SE cams. There are much better choices out there, like Andrews 48s. I'm not a fan of 255s at all, but in a stage 1 96" bagger with a "geezer" rider they aren't a terrible choice. Get a proper dyno tune by someone that know what they are doing.
Old Jun 20, 2014 | 09:54 AM
chief1600's Avatar
chief1600
Originally Posted by BrownSanta
I have the extended warranty and I went with the TW222's from FuelMoto after talking with Jaime. And my dealer did the work with no issues.
I went with the TW222's and had the install done at FuelMoto. Here's the result.
Old Jun 20, 2014 | 10:52 AM
user 8373900's Avatar
user 8373900
Originally Posted by Kokes58
I have an 09 Ultra currently with stock header and 3 1/2" Reinheardts. The motor is currently stock except for the Big Sucker and a Screaming Eagle Race Tuner. I'm considering going with a V&H Power Duals Header and the 3 1/2" Reinheardts. Since I would have to get it tuned again, this would be a good time to change out the stock cams. I need to stay with a Harley brand due to the extended warranty I have. I'm thinking the SE255s but would like to get some thoughts. I do a bit more open road riding than city type riding. I shift for the most part between 3,000 & 3,500 RPMs. Would the 255s give the power in the band I ride or is there another one I should look at.
Thanks
Your bike doesn't have the compression releases it needs for the 255. Unless you like to buy and change starters the 255 is wrong for you. there are plenty of choices out there that don't have hard starting issues. Look at the S/E 204.
Mark
Old Jun 20, 2014 | 11:01 AM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by harley7316
2011 street glide 254E working well here
damn took someone long enough!!
SE255 cams are excellent grunt cams; take a look at dyno charts to see how they come on in the lower RPMS and hang in there for a little while til they peter out.
SE254E cams IMO are a better option for cruising in the RPM range you're talking about. They have the needed grunt at the bottom (granted not as much as the 255) but they carry further out to the right (HP) than the SE255 does so you get the best of both worlds.
Either one of these cams requires someone who knows what they're doing to tune them properly. There aren't many HD shops around the US that know how to tune worth a flip so my suggestion would be ask around for someone in your area that can tune with the device you have.
If you choose to go aftermarket, take a look at the Andrews 48H. Excellent cam with a tad bit better manners than either of these 2 SE cams.
Old Jun 20, 2014 | 11:35 AM
journeyman's Avatar
journeyman
Been running the 255s in my 2011 SG a couple years now and still find them to meet my needs perfectly.
The way I see it is, the power band of those cams is in it's peak where I spend over 90% of my time.
Sooner or later you will find you will need to 'get on it' for an evasive maneuver, probably due to someone pulling in your lane or whatever.
The last thing I would want to do is have to down shift to get peak performance.
If I where to change my riding style to more of a racing type, I might reconsider the trade off of where the power band kicks in best, for now there is harmony in the universe with the 255s.
Old Jun 20, 2014 | 11:57 AM
UltraNutZ's Avatar
UltraNutZ
no doubt man.. there is a cam for every build and every riding style.. I've only run the 255s personally in an early 96" and didn't care for them. Came on too quick and fell off too fast. Switched to the 254e which was a huge improvement for me/my riding style and then switched to the 48H of which it was by far the best of those 3 for me. None of the 3 required me to downshift for evasive maneuvers or passing someone. I can tell you that the 48H does not work real well in a 103.
Old Jun 20, 2014 | 01:44 PM
Pappy1's Avatar
Pappy1
09 Street Glide Here....96ci...V&H power duals...Screaming Eagle Heavy Breather...Race tune...255 is what the dealer said would be the best all around cam for me on that set up...so Sounds like your on the right track
Old Jun 20, 2014 | 02:18 PM
fwb35's Avatar
fwb35
SE 204 is the best HD cam I have tried, the SE 255 is not much more then stock.
Old Jun 20, 2014 | 04:13 PM
wurk_truk's Avatar
wurk_truk
If I had to stay SE on cams for a 96", go with the 204s. 255s make too much compression when hot and you will wish you had compression releases installed.
If you already own one, fine... but I would NOT be buying any SEPST tuner, they will discontinue that tuner completely very soon... along with all the new calibrations, etc. No more updates. Two things happened. SPX (the maker of the SEPST) was sold to Bosch, and also EPA must have busted the chops of the MOCO, because have you EVER seen a car company sell a tuner? That is a big NO, because it is a huge no no in todays world. Bosch is not going to put up with the hassles.
Buy TTS, or if you must... a PV.
Soooooooooooooooooooooooooooo... ANY dealer that tells you to buy a Super Pro Tuner is a dealer that sucks big time. Same with the rest of their advice.
Install 48s for the best riding bike, IMHO. SE cams are not all that anyways. Unless you are having the dealer install the cams? Who would really know you have 48s instead of 204s anyways? Plus, for extended warranty? Neither cam will be warranted if something happens anyways. Warranty MAY be covered by the selling dealer, but that is NOT the same as having a complete warranty. Bright side is neither cam, in and of itself, will do ANY harm to your engine... as long as it is tuned properly (that means not by a dealer).
Since you ride above 2500, the 204s would work better for you than the 255s any day of the week.
Nutz? a Torqester 555 cam from TMan works very well in a 103, and is NOT to be confused by others junky 555s.
