Cracked windshield
Old Jun 30, 2014 | 09:16 PM
cruzin924@yahoo.com's Avatar
cruzin924@yahoo.com
Stage II
Default Cracked windshield
Hi, my name is Jerry I ride a 2010 FLHTK, has anyone experienced their windshield cracking from the area where the screws hold it on. It started when I switched my stock one out for a 12", but I noticed the stock windshield was starting to crack also. I'm now looking at replacing the fifth windshield. All work has been done by Harley Dealer and their dumbfounded also. They don't show a history of this problem with the FLHTK's.
Old Jun 30, 2014 | 11:34 PM
mkguitar's Avatar
mkguitar
the fairing/windscreen is same from 1996 to 2013.
I run mine pretty loose- I wonder if someone is cranking on it-?
the HD lexan is pretty tough, that's for sure.
some of the aftermarket windscreens are brittle- I have seen them shattered by rocks and hail.
depends what material they use
mike
Old Jul 1, 2014 | 01:13 AM
2AMGuy's Avatar
2AMGuy
Community Influencer
With that many windshield failures something must be wrong.
My first thought of course is the screws that secure the windshield tightened correctly and is there any "slop" between the inner and outer fairings and is the inner fairing well secured to the forks?
The second would be, is to compare this bike's upper fairing area to see if there are any differences.
Lastly, any chance that someone may be tampering with your bike?
Old Jul 1, 2014 | 09:50 AM
Wild Duck's Avatar
Wild Duck
Are you putting a cover on your bike?
Old Jul 1, 2014 | 12:40 PM
cruzin924@yahoo.com
Stage II
Thanks for everyone's replies, all that has been mentioned has been tried or examined by Harley Dealership.. My bike is garaged.
Old Jul 1, 2014 | 09:30 PM
2AMGuy's Avatar
2AMGuy
I've been thinking about this problem and there has to be a logical reason that your windshields are cracking.
Did the dealership check both inner fairing brackets?
Old Jul 1, 2014 | 09:38 PM
miner999r's Avatar
miner999r
if the cracks aren't too bad you can stop drill them. Use a 1/8 drill or smaller and drill a small hole at the end of the crack. Learned this from airframe mechs.
Old Aug 10, 2014 | 04:51 PM
Billy Edwards's Avatar
Billy Edwards
I'm going through the same thing on my 2013 RG Ultra. I've never touched the stock windshield - only the dealer has. It started cracking last fall, not longer after I bought the bike, and I didn't worry about it until I took it in last week for other service. I asked if warranty would cover it. The answer: No. I'm not a happy HD customer right now. The bike is a year old and I only have 6K miles on it. The windshield shouldn't be cracking. It's cr@p.
Old Aug 10, 2014 | 05:54 PM
103 sedona orange's Avatar
103 sedona orange
Question Not Happy With the Dealership
[QUOTE=Billy Edwards;13088124]I'm going through the same thing on my 2013 RG Ultra. I've never touched the stock windshield - only the dealer has. It started cracking last fall, not longer after I bought the bike, and I didn't worry about it until I took it in last week for other service. I asked if warranty would cover it. The answer: No. I'm not a happy HD customer right now. The bike is a year old and I only have 6K miles on it. The windshield shouldn't be cracking. It's cr@p.[/QUO
I disagree with you. You should have taken it back when you first noticed it. Maybe the dealership would've taken care of it then.
Old Aug 10, 2014 | 11:05 PM
reddog8145's Avatar
reddog8145
Just got mine replaced on warranty, just before it expired, same thing as yours, the new windshield perspex appears thicker than the old.
