mity vac
Old Jul 1, 2014 | 05:22 PM
dochawken's Avatar
dochawken
Default mity vac
I was watching a video on this device for brake or clutch bleeding. Why not just go to a feed supply store such as tractor supply and for 3$ purchase a 50 cc syringe? I did a new clutch and brake line using speed bleeders and this method...worked exceedingly well. Can't beat the price...Just a thought for any that enjoy cheap and easy hydraulic work.
Old Jul 1, 2014 | 06:10 PM
lp's Avatar
lp
I've done exactly that (and I have a mity vac too).
I usually reverse bleed the brakes, pushing fluid up into the master cylinder using a large syringe.
lp
Old Jul 1, 2014 | 07:53 PM
dochawken's Avatar
dochawken
lp
I used the speed bleeders with the check valve so it was easy for me to just zip tie the lever open and suck it from the master. 5 minute job..no air in the line... 3$ outlay. Love those speed bleeders.
Old Jul 1, 2014 | 08:30 PM
trnewman's Avatar
trnewman
Can this be done if you have ABS?
Old Jul 7, 2014 | 07:08 PM
dochawken's Avatar
dochawken
[QUOTE=trnewman;12934978]Can this be done if you have ABS?[/QUOTE.
I see no reason why not...gets all air out of the line. It works amazingly well..
Old Jul 8, 2014 | 08:56 AM
grbrown's Avatar
grbrown
Red face
I've been bleeding brakes for decades, since I helped my Dad on the family cars. As for bikes and more recent experience, I have a Mityvac and have also tried other products over the years. To be frank I haven't found any one that works better than the others. When the gods are in a good mood and the stars are all aligned, by far the quickest way is the traditional piece of hose and a bottle. However the ideal conditions do not often arise, hence the popularity of the many 'fixes'.
97EGC
Aug 12, 2015 06:46 PM
jekyllandglide
Apr 15, 2015 10:25 AM
metobyl
Oct 12, 2013 10:36 PM
sddyna
Oct 19, 2009 08:28 AM
badbag
17
Jul 30, 2009 12:58 AM
