cutting antenas
Old Jul 3, 2014 | 12:46 PM
FLHTCU Owner's Avatar
FLHTCU Owner
Originally Posted by mikeo33y
anybody ever cut down there antennas. if so will the plastic end pieces come off to put back on after cutting. i hate those long a** antennas. i dont really like the shorty ones sold in the HD catalog
Yeah, that's what I did to mine. If you raise the rubber boots up, you will see the set screws, just loosen those and you can slide the whips out, and cut from the bottom.
I have no idea how it effects the CB as I don't use it, but it had no adverse effect on the radio reception cutting the radio whip.
Old Jul 3, 2014 | 05:54 PM
YPD485's Avatar
YPD485
Originally Posted by spr0k3t
True that. If you have an swr meter you can eyeball it. The swr works in a phase so chopping could throw it way off, a few millimeters down could put it right back. It's all in the length. The scary thing is, you can make a good cb antenna out of lawn chairs with the right swr rating once done.
Harley should have used old lawn chairs for the 2014 CB's since the SWR is way off and has a range of maybe a couple hundred feet.
Old Jul 3, 2014 | 07:29 PM
themensh's Avatar
themensh
Do what you want with an AM/FM antenna.....but a CB antenna is TUNED. Mess with a CB antenna length and you risk destroying the CB.
Chuck
Old Jul 3, 2014 | 08:28 PM
103 sedona orange's Avatar
103 sedona orange
Not sure if the end cap will come off. I'd check at NAPA for caps that fit vacuum hoses. I'm getting ready do do the same thing.
Old Jul 3, 2014 | 08:59 PM
bike_r_trash's Avatar
bike_r_trash
Try finding someone who owns a pre-14 Limited. The stock antennas are shorter than the stock ones on other touring bikes and longer that the shorty versions you don't like.
Old Jul 4, 2014 | 08:35 AM
BoonDock_Saint's Avatar
BoonDock_Saint
That. I removed my CB antenna and used two pieces of shrink tubing (little square for the top and tube for the threads) to cover the threads on the mount.
Old Jul 4, 2014 | 09:26 AM
Uncle Larry's Avatar
Uncle Larry
I took both antennas off and covered the "stubs" with a vacuum caps from one of the auto parts stores. I've never even turned my CB on but I do have a "shorty" antenna in the bottom of the tourpak for that "just in case moment.
Old Jul 4, 2014 | 10:14 AM
Muttleybass's Avatar
Muttleybass
The rubber cap comes off my 2010 antenna. I don't see why you couldn't lop a few inches off.
Like other's have said, the CB ones are different, but the AM/FM ones are fair game.
Old Jul 6, 2014 | 10:54 AM
Fox2kill's Avatar
Fox2kill
Lop away on antennas that receive-only (AM, FM). Lop away on a CB antenna if you never transmit on it. But, transmit on a lopped-off CB antenna? If you're lucky the CB radio will live through it. Better to use a short loaded antenna (plenty on the market).
Old Jul 6, 2014 | 02:56 PM
Lowcountry Joe's Avatar
Lowcountry Joe
It's amazing the misconceptions out there regarding antenna resonance and tuning.
Antennas that are used for transmitting and for receiving are both tuned and designed for use in a particular part of the RF spectrum. That goes for the two antennas on your Glide. Trimming a receive antenna (such as for FM or AM broadcast receive) won't do anything damaging to the equipment other than de-tune the antenna and decrease it's efficiency even more at the designed operating frequencies. Cutting an antenna used for transmission (in this case your CB antenna) if you don't know what you are doing and don't have the proper monitor/measuring equipment, and if your transmitter does not have reflected power protection, you will certainly damage the transmitter (usually burn out the final amp transistors) if a de-tuned antenna is used for any length of time.
But hey, it's an HD. Looks are always more important than performance, right?
