electra glide touring antenna relocation ideas?
Old Jul 18, 2014 | 06:04 AM
Spartanden's Avatar
Spartanden
not sure if this will help you or not, but i went to O'Reilleys and bought a shorty replacement mast and swapped mine out. It is about 16" tall compared to the 30"+ stock mast. Just a screw mount on the base. Reception is still pretty good. The shorter length looks better in my opinion.
Old Jul 18, 2014 | 06:21 AM
Iceman24's Avatar
Iceman24
Hidden antennas (powered) work well, but need to be cautious on grounding points when you also have LED lights in fairing. Best to ground direct to frame vs. battery...otherwise your reception could be impacted.
Old Jul 18, 2014 | 06:26 AM
hAkron's Avatar
hAkron
There were a few posts about just using a regular shorty antena and just zip tie it to the wire bundles inside of the fairing.
Old Jul 18, 2014 | 07:21 AM
sunderhill's Avatar
sunderhill
Will this help you out?
Old Jul 18, 2014 | 08:30 AM
dgdamore's Avatar
dgdamore
The MoCo's antenna relocation kit will work on an EG. Also, it's been my experience, the factory antenna works the best at clear reception.
Old Jul 18, 2014 | 10:15 AM
rob0225's Avatar
rob0225
Originally Posted by adamsrotors
the bracket I believe is a street glide thing..mine is mounted to the trunk...
...the fairing mount is not easy or cheap.
does any automotive antenna use the same attachment as our HD antennas?
The bracket works on the EG. I just did the tour pack detach kit and installed the bracket. I'll take a picture later and post it.
Old Jul 18, 2014 | 10:35 AM
jamess71's Avatar
jamess71
I need to do something too. I installed one of the in fairing type and reception sucks.
Old Jul 18, 2014 | 12:05 PM
CBRTRX's Avatar
CBRTRX
Originally Posted by sunderhill
I tried that on my 14 when I first got it, reception was not very good so I put it back.
Old Jul 25, 2014 | 12:25 PM
adamsrotors's Avatar
adamsrotors
I like the idea of the stubby. I wanna mount it to my bag.
do they attach to the HD wiring just the same? is that a generic antenna attachment?
talking about the screw-on portion.
Old Jul 25, 2014 | 12:58 PM
SeaZund's Avatar
SeaZund
It doesn't work well because letting it hang loose like this loses the ground path. The antenna needs to be grounded to the frame.
