any real adv between the hard mount and the cable adj backrest??? my wife doesnt like to ride with one between us, how easy/fast is either to remove for a ride??
Hey Relli, I've been thinkin of gettin one too and looked into them last summer. I would definately get the adjustable one so you can change up positions on long runs, and from what I see when you want to remove em (at least on the HD one), it looks like you basically just squeeze the 2 sides of the support bars together and pull it up. Should be 2 seconds to remove from what I've seen....
Don't waste your hard earned money on the cable adjustable one. The standard will move to any position, up/down, back and forth as the other one. But, I've found that once adjusted, I've never had the urge to move it. Kinda like the power seats in your car, when you get 'em set, you rarely move them. As for the backrest itself, they're both the same. Just squeeze the legs and pull it out.
I totally agree with Chris. I have the one without the cable adjuster, and love it. When I first got it, I kept changing the angle and height in search of the perfect position. Now that I have it 'dialed in,' I can't imagine making any new adjustments. BTW, its a piece of cake to remove and re-install. Once you've done it a few times, it takes only seconds.
