Not enough oil
Old Jul 22, 2014 | 06:47 PM
  #31
Gbtech's Avatar
Gbtech
6th Gear
With bike upright, check the level, it should just be up to the outside diameter of the outer clutch shell. Don`t overfill, but a little low won`t hurt a thing.
This the correct fill. It doesn't matter how many oz it is. 99% of the time 1qt will get it there.
Old Jul 23, 2014 | 09:10 AM
  #32
Hotrodz_n_Harleyz's Avatar
Hotrodz_n_Harleyz
Originally Posted by KCFLHRC
Why would you take the chance, just put in the 38 oz. per the manual. The guys that are saying less than that is enough will be no where around when your primary is toast. This is the internet, don't believe everything you read here. But you can believe your manual.
Yeah, because the absolute precision tolerances that we all know Harley drivetrains are famous for will be incredibly adversely effected by a few ounces of oil either way in what amounts to a tub with a chain spinning on a couple sprockets slinging said oil all over the place. Makes perfect sense. Wear a lab coat and rubber gloves while you measure it out to for best results.
And this isn't even taking into consideration that just draining and refilling your primary isn't close to exact as far as amount goes. you never get everything out when you drain it. I've never measured for my primary. Just fill the damn thing to the correct level on the clutch, put it together and ride it. 98 thousand miles on mine, and everything in the primary is still what came new with the bike. including the clutch.
Old Jul 23, 2014 | 10:03 AM
  #33
Leftcoaster's Avatar
Leftcoaster
Originally Posted by btsom
On a re-fill, how much that NEEDS to go in depends on how much came out. If you used some of the tricks found on line to get a thorough drain you will need more than if you just casually drain and re-fill. The manual tells what "full" looks like and it suggests about 38 ounces so you have enough on hand. Fill to the proper level as per the manual, end of discussion. This is like, if your car manual says you have an 18 gallon fuel tank, you insist on pumping 18 gallons of fuel at every fuel stop no matter how much runs out on the drive as you pump.
Sorry for calling you out here, but.....
I've been trying to find exactly where any shop manual says "round about 38 oz. should do it" - maybe you can direct me to the exact page?
And refilling only the amount that is removed is ****-poor maintenance at best. Particularly if there's any leakage, etc.
My experience is this: I have yet to find a primary calling for a 38 oz. refill ever to be over filled regardless of how much is drained out. If it's drained, it's drained - casually or formally (WTF?).
Old Jul 23, 2014 | 10:19 AM
  #34
KCFLHRC's Avatar
KCFLHRC
Old Jul 23, 2014 | 10:56 AM
  #35
SmokeyJoe101's Avatar
SmokeyJoe101
Hey I guys in case some of you missed it. I leveled the bike, took the cover off and filled it like the diagram on the 1st page of this thread.
Old Jul 23, 2014 | 11:42 AM
  #36
SmokeyJoe101
Man I am jinxed. So I am on my home from work(right now) and the clutch just went out while sitting at a light. I have the hydro clutch and there is absolute zero pressure on the lever.
I sit a n wait for the truck.
Old Jul 23, 2014 | 11:28 PM
  #37
SmokeyJoe101
Smile
Oh great, now where are the suggestions and recommendations. No one wants to touch this thread with a 10 foot pole now. I see how you all are.
Old Jul 23, 2014 | 11:59 PM
  #38
Retrop's Avatar
Retrop
Jeez guys, it is amazing that this has turned into such a discussion about 32 oz., 38 oz., or 45 oz. Remove the derby cover and shine a flashlight in there so you can see if oil touches the bottom of the clutch basket. If the primary oil does not touch the bottom of the clutch basket then put in some more until it does. Don't worry about how many ounces of oil are in the primary, only worry about whether or not it touches the bottom of the clutch basket. It the oil touches the bottom of the clutch basket it will have the required 45 ounces in it. If it has a little more in it, don't freek out. It won't grenade.
Ride more and worry less.
Old Jul 24, 2014 | 04:33 AM
  #39
skiddd's Avatar
skiddd
So is a freaking ounce a metric measurement? Or is it the same as a regular ounce?
It is an insignificant amount when talking about primary lube.
lol, awesome..................
Old Jul 24, 2014 | 05:38 AM
  #40
RBWIDE's Avatar
RBWIDE
ROTFLMAO! Best response so far, by far!! The AR factor of some riders is on display in this thread for sure! Relax. A couple of ounces low will not harm your ride. Two shot glasses? C'mon man!
