Dumb questions
Old Jul 26, 2014 | 07:21 PM
sick06FLHX's Avatar
sick06FLHX
Default Dumb questions
Dumb rookie questions for you guys....
Used to a sportbike, I could check my oil on my stand... Just so I know I'm reading this stick right - it has to be stood upright?
Also, voltmeter is reading 16 volts.... Is this good, bad?
Old Jul 26, 2014 | 07:30 PM
dawg's Avatar
dawg
Your volt gauge may not be accurate, test with a voltmeter to be sure. However, it could be a faulty VR as that was an issue on the 06's and had a recall. You can check oil on the jiffy while warm.
Old Jul 26, 2014 | 07:34 PM
sick06FLHX's Avatar
sick06FLHX
Hmmm so might actually be a quart low? I wonder how much a voltage regulator costs. Any idea how to test if its the VR?
Old Jul 26, 2014 | 08:02 PM
dawg's Avatar
dawg
http://blog.jpcycles.com/step-by-ste...arging-system/
Old Jul 26, 2014 | 08:19 PM
Joe12RK's Avatar
Joe12RK
harleys have marks for both side stand and upright on the dipstick - check either way but warm
Old Jul 26, 2014 | 10:30 PM
Streetrunner's Avatar
Streetrunner
I always screw mine down then take it out for the reading. Sometimes I wonder if you should take it out, wipe it off then let it go down to the point before pushing or screwing it down tight then lift it out for the reading. What is the proper method.
Old Jul 26, 2014 | 10:40 PM
skiddd's Avatar
skiddd
Good info to save, thanks Man......
Old Jul 26, 2014 | 11:41 PM
dochawken's Avatar
dochawken
Dawg always has great input..right to the point.
Old Jul 27, 2014 | 01:49 AM
SafetyMan's Avatar
SafetyMan
You are supposed to screw it in until it stops, then unscrew and read.
Old Jul 27, 2014 | 01:52 AM
rmalicki's Avatar
rmalicki
Stage III
You can check the harley on a stand as well. Sport bike and Harley have many many similarities.
