Drag specialties wheel bearings
Old Jan 10, 2017 | 06:21 AM
Sc0-'s Avatar
Sc0-
HD revised the part number and they are now South Korea made. The NSK bearings that i replaced my Mexico bearings with were made in Bulgaria.
Old Jan 10, 2017 | 06:56 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Originally Posted by tommyglide
The wrapper on the last HD wheel bearings I bought said made in South Korea, popped the seal off to have a look see and very little grease was in the pos. Now have World Wide Bearings ceramic pieces, pricey, probably not neccessary but through misadventure learned they can take a pile of heat without deteriorating. The proprietor's customer service is darn good also.
Dude grease fill in a sealed radial ball bearing is only about 30% at most. You do not want them completely full! Grease lubricates but at the same time it will act as an insulator and hold heat in. If it was completely full of grease the bearing would run hotter , heat creates friction and friction causes wear. Also keep in mind that on Harley front wheel they probably never see more than 120 degrees F. In the back with less air flow and exhust a little higher. These are very normal operating temperatures.
Ceramic is way overkill. I have never sold a ceramic bearing for any application less that 350 degrees F. My concern with ceramic is from what I have been taught by manufacturers they are not good for application with shock load. I would not feel safe with them on my bike.
Old Jan 10, 2017 | 06:59 AM
Cosmic Razorback
As mentioned in an earlier post the key is to buy a bearing from a major manufacturer. Everyone of them produces all around the world now.
NSK is one of the best. They are a Japanese company and currently the largest bearing supplier to the automobile industry. Don't worry about which country it was made in but instead who made it.
Old Jan 10, 2017 | 10:59 AM
Boomer1143's Avatar
Boomer1143
I renewed my wheel bearings 10k ago with ABS bearings from Drag Specialties and the non ABS from All *****. So far so good.
Old Jan 10, 2017 | 08:12 PM
not a sock's Avatar
not a sock
I got the bearings, ABS and non-ABS for my '16 FLSTC from All B a l l s as well.
Sorry my friend, but they are KML and according to another poster, looks like they are Chinese...............
Old Jan 10, 2017 | 08:22 PM
farmboy555's Avatar
farmboy555
I also just go to NAPA or our local bearing shop and get all mine. Never go to the dealer for a wheel bearing
Old Jan 11, 2017 | 03:44 PM
Musician's Avatar
Musician
Default wheel bearings
I don't know what everybody else does, but my '08 FLHT now has well over 100,000 miles on the bike, and I'm just now getting ready to change the bearings. I've kept track of them every season by removing the wheel and closely inspecting rotation, drag, lateral movement, anything else I can think of. They are just barely starting to show wear and clearance, but within specs on wheel runout, etc. Probably good for another year, but replacing tire, so a good time to do the bearings. If I didn't know they were cheap foreign crap, I might have been worried.
Old Nov 11, 2018 | 02:22 AM
OakMountainRider's Avatar
OakMountainRider
Originally Posted by Cosmic Razorback
Apparently something has changed because my experience over the years has been that the Harley bearing was dimensionally different that's any of the 6200 and 6300 series radial ball bearings. I wish I had a dollar for every time a customer came to my counter wanting a HD bearing that we could not match up.
If the 6205 is the correct bearing now you are MUCH better off going to an actual bearing house like Applied Industrial Technologies, Motion Industries, Kaman, Bearing Distributors, etc. there is one in every major town.
The brands you want are SKF, F.A.G., NTN, KOYO, NSK, NACHI
As for Timken they are a Tapered Roller Bearing company. About 15 years ago they purchased Fafnir bearing which makes ball bearings. They have a good product also.
The SKF number posted earlier breaks down to:
6205-2RSJEM
6200 = Series
05 = Bore 5 x 5 = 25mm
2RS = two Rubber Seals (sealed both sides)
J = steel retainer (this separates the *****, some steel, plastic, bronze)
EM = Electric Motor Quality
The Germans invented the bearing and SKF was the company. I have long considered them the best in the industry. Keep in mind that bearings have become a victim of the world market. Most all major manufacturers have plants in every region of the world including China. You are safe as long as you by a major name brand bearing. Their quality is consistent around the world.
However there is a LOT of JUNK in the bearing market. I would never by a bearing from someone like Drag Specialties. Who made it? What ABEC rating is it? Are the seals good? What grease did they put in it? My life rides on these. Like tires the last thing you want to cut corners on to safe a few bucks.
Harley has had issues with bearings. But they have their reputation riding on them. They as a manufacturer know who made them and they know the standards they meet. If you can get an SKF or other major brand in the size you need go for it. If not I would trust Harley and spend the extra 20 bucks.
I have been in the industry 40'years and have been to most all the major manufacturers s training schools. Just my 2 cents.
Was looking around for good steering bearing to my Dyna and found this useful post. I really like to get another bearing than Drag, and if I could find SKF I would buy it. However, SKF is a Swedish company, not German. The name is: "Svenska Kullagerfabriken" and it was established 1907.
Found this on Ebay, but I do not know if it suits. It only says it is for Harley big twins: https://www.ebay.co.uk/itm/Harley-Da...t/361989887003
Old Nov 11, 2018 | 04:28 AM
JayStronghawk's Avatar
JayStronghawk
Will keep this in mind NSK should be as good as any .. Wanting to go to Timkin Bearings on my inner Cams was plainly told Koyo is the best going to find out there now and so far they have done Great ..
Old Nov 11, 2018 | 07:58 AM
multihdrdr's Avatar
multihdrdr
BTW ... Torrington Needle Bearings = KOYO Needle Bearings
Timken (who had acquired Torrington) sold to the Group who also owns KOYO = KOYO Needle Bearings
