2012 RoadKing with TW555 cams
Old Aug 8, 2014 | 10:46 AM
jzee63's Avatar
jzee63
Stage IV
Default 2012 RoadKing with TW555 cams
I bought my bike from the dealer with Vance and Hines slip-ons and a stage 1 air cleaner kit. I later installed V&h dresser duals. I now wanted to get my bike dyno tuned and decided to also get TW 555 cams installed at the same time. Now my idle seems rough and erratic and my mpg is down from 40-42mpg to 31-33 mpg. The bike was tuned using a Screamin Eagle race tuner. I found a vacuum leak so I took the bike back to the tuner. He fixed the leak and it was put on the dyno again. Still the idle doesn't seem right to me but he says everything is good. Just wanted to see if there was anyone with a similar bike who has had the TW 555's installed and experienced the same issues.
Old Aug 8, 2014 | 11:51 AM
Tn.Heritage's Avatar
Tn.Heritage
I had this combo in a 106" I recently built before I traded for my 2014 and had it set up at 10.45 compression. If it's tunes right the idle will be a little lumpy but not all that rough. Do you have a dyno sheet that shows the afr graph on it ? Also the idle enrichment may be set too rich on the start up and the afr may be too rich also.
By the way my bike ran awesome, 110hp and 128tq with those cams.
Old Aug 8, 2014 | 11:54 AM
Eshaw301's Avatar
Eshaw301
Nope, not the same issues. Again...this is the reason I always recommend that people use a power commander instead of a dyno. Now, you are gonna spend more time and possibly more money trying to get it right when you could just avoid it all and go with the tune that has been tried and true thousands of times over. I sure hope you get it figured out....
Old Aug 8, 2014 | 12:34 PM
jzee63's Avatar
jzee63
Stage IV
I remember the tuner stating that the idle enrichment on start up was set to the lowest allowable value. I have a dyno sheet at home which I'll look at later. The tuner I used is a very reputable, well known guy from my area, recommended to me by many people. He told me that the Screamin Eagle race tuner would give me a much more personalized tune as opposed to a more generic tune from a power commander. Its been 20 years since I owned my last Harley and things have changed a bit since then so I trusted his opinion and the referral of him by others.
Old Aug 8, 2014 | 03:23 PM
Gunnysgt's Avatar
Gunnysgt
I have a TW555 cam in my 2013 Road King, Stage 1 with V&H Dresser duals and SuperTrapp FatShotz. I have the SE Pro Super Tuner, the "race tuner" hasn't existed for several years. The bike has a slight lope on idle but runs really really good. I get about 42 mpg hiway, 36 in the city. I personally would NOT put a power commander on any bike that has TBW, I've tried in a few and the throttle by wire bikes just didn't do as well as they did with a flash type tuner like the SEPST, TTS etc. They PCV was fine on my pre TBW bikes and "OK" on the newer ones but not like it should. Power Commanders are throttle position based tuners, TBW is Lambda based, it just works better with a flash tuner.
Old Aug 8, 2014 | 10:23 PM
monumaker's Avatar
monumaker
A piggy back tunner w a bogus map Is better than a pro tunner and a real dyno tune???
What are you smokin dude?
Old Aug 8, 2014 | 10:30 PM
jzee63's Avatar
jzee63
Stage IV
Thanks Gunny, Your're right with the tuner. Mine is a super tuner also. I will be making a trip from Long Island NY to Maine next month. That should give me a good read on the mpg. My bike runs well also, the idle just seems a little funky. I'm a foreign car auto mechanic so I know quite a bit about fuel injection systems. If my bike was a car, I would say that it had a bad O2 sensor based on the idle fluctuation. Maybe its just me
08FXDL
2014-2024 Touring Models
35
Sep 16, 2016 07:01 AM
HarleyDawg
28
Aug 31, 2016 04:04 PM
Vic hale
Mar 19, 2014 05:55 PM
gedo76
Exhaust System Topics
Nov 12, 2011 10:59 AM
Blown 331
May 5, 2010 07:31 PM
