03 Ultra lost power
Old Aug 15, 2014 | 10:46 PM
ASmith's Avatar
ASmith
Stage IV
Default 03 Ultra lost power
hey... got stuck in Chicago traffic.... stop in go for hour in half at least.. suddenly lost all power.. radio went dead.. all gages.. motor not running. Clicked on off switch while hitting start button... nothing. Get it to side.. do a quick over to make sure nothing noticeable. hit start button.. fires up.. dies immediately at idle. 5 min wait.. start up and get it to an overpass..not running to good. wait 15 minutes... cool off. start it up and go hour n half to 2 hours home.. no more problems. Is there a sensor that senses heat and shuts down? Should I be worried about something?
TIA
ASmith
Old Aug 15, 2014 | 11:55 PM
fxdxruss's Avatar
fxdxruss
Maybe loose or corroded connection, all that heat caused increase in resistance. Cooled down problem went away. I would check the connections do the ECM module or the tssm module.
Old Aug 16, 2014 | 12:47 AM
Bill03E's Avatar
Bill03E
I would be willing to bet that it tripped the main circuit breaker , they are in front of the battery , and when they get hot they can trip. You can help it out by replacing the ring terminal on the silver post with a thicker heavier ring terminal, and make sure it is a 50 amp breaker, because there was a campaign that replaced the 40 with a 50 amp.
dirtydave98
Nov 1, 2013 10:13 PM
RidemyEVO
EVO
13
Sep 19, 2011 03:21 PM
sifularson
Jul 10, 2009 12:41 PM
bigdaddy405
Oct 1, 2007 08:13 AM
controlseng
Jul 16, 2006 02:35 PM
