Swingarm alignment...
Old Aug 17, 2014 | 01:16 AM
OwnerOfHarriet's Avatar
OwnerOfHarriet
I never had any problem with 402's following the rain grooves
As far as alignment, Glide Pro has a good video
Old Aug 17, 2014 | 09:04 AM
Jumpman's Avatar
Jumpman
Originally Posted by lp
+1 If he's running those stock Dunlop 402's or whatever they were with the staggered tread pattern deals the bike is going to be all over the grooves.
The fix is new tires that don't hunt grooves...
Tires are Avon Cobras. Front is new (just installed like 2-weeks ago). Rear is about a year or so old.
I pulled the swingarm yesterday and tried to check it against my old one to try and determine if it was bent. Both parts have very similar characteristics...so...they are either both right, or both bent.
I reinstalled and made sure (just like last time) that all torque specs are correct. I need to make sure the rear wheel/belt tension is right...and then, weather allowing, do a test ride.
Old Aug 17, 2014 | 10:44 AM
grbrown's Avatar
grbrown
You have a very high spec build there! I'm working towards a similar spec myself, with a few additions. The only thing I can see missing is a rear stabiliser, actually the first thing I added to my own bike. In view of the other things you've done, if you don't have one use a True-Track.
As for the levels. the only suggestion I have is vertical alignment of the engine in the frame, however I wouldn't put too much confidence in precise accuracy of the build of the frame. It may well be that with everything at it's optimum, the seat rails for example are not actually level.
Old Aug 17, 2014 | 11:31 AM
bigheadted's Avatar
bigheadted
Maybe the swingarm "arms" not being level with the frome is not the important thing here.
The centerline of the rear axle would be the important thing ?
Old Aug 17, 2014 | 12:12 PM
Recycled's Avatar
Recycled
This is what I would be checking as well. With everything else you have listed as being done, the alignment of the rear wheel in relation to the front wheel should be checked. You could use the 8' florescent tube method, holding it across both rear and front wheels or take it to someone with the laser alignment tools. I would also install one of the stabilizers on the market. Good luck!
Old Aug 17, 2014 | 10:03 PM
Jumpman's Avatar
Jumpman
To answer the stabilizer question... I am running a Smooth Rider stabilizer.
I need to find an easy way to use a straight-edge to verify front/rear wheel alignment.
- the 8' fluorescent bulb is a great idea...except ther is no room to do so because my exhaust & lower fairing is in the way. Also, since I am running a single-sided brake up front now, I have to work from both sides of the bike.
Kinda sucks
Old Aug 17, 2014 | 10:25 PM
lp's Avatar
lp
Kinda sucks
Maybe a piece of string wrapped around both tires along the bottom edge of the tires? I've done that with cars to check camber anyway.
Note: Not all touring bikes from all years are completely inline tire wise.
Some bikes have the rear kicked off to one side a few mm or more depending on how much offset was needed to put a belt inline with the rear tire pulley. Came that way from the Factory.
The important thing is to make sure both are running straight in relation to each other.
Old Aug 17, 2014 | 11:41 PM
Recycled's Avatar
Recycled
There is another method that I have used to check for parallel tracking:
-Position the bike in an exact upright position, using plumb bobs originating on the upper sidewall of each tire. (I did this with the bike on the lift using shims.)
-Draw a line on the floor, perfectly parallel with the contact points of the plumb bobs, extending 2' beyond the length of the bike on each end.
-Now you can use a shorter straightedge with a plumb bob hanging from each end, to span both front and rear wheels individually, to scribe/draw a directional line for each wheel and gauge the difference in tracking between both wheels.
Its a bit of setup and kind of caveman style but does work. This method will allow you to see both horizontal and vertical planes of each wheel allowing you to make corrections.
When I set mine up after building the modified swingarm, I used a combination of a laser, plumb bobs and straight edges using this method. My bike tracks and takes the sweepers like its on rails at any reasonable speed I've gone. Hope this helps, Good Luck!
Old Aug 18, 2014 | 12:29 AM
Shanebo's Avatar
Shanebo
Reading with some curiosity here...sounds like you have done a lot of work to make the bike handle as well as possible.
In the first post, you reference that the issue is related to grooved or uneven pavement, yes? A couple of questions that might help focus in:
1. Does the bike handle to your satisfaction on other surfaces, like gravel, smooth pavement, chip seal, crowned two-lanes, etc...?
2. Assume that you have just resolved the issue--what does grooved or uneven pavement feel like to you now?
My experiences on grooved, uneven, and freshly chewed up (ready for resurfacing) roads have been all kinds of different over the years, depending on bike, tires, suspension, and other factors. Grate metal bridges are the worst, and when they're wet, even worse.
The thing I have found to work best is to loosen up my hands, and like a horse, let it have it's head. Not sure how loose yours is feeling, that's why I asked the questions above, to try and get a better sense of your feeling and expectations.
All the best,
Shane
Old Aug 18, 2014 | 08:03 AM
grbrown's Avatar
grbrown
Thumbs up
I have a 2007 swingarm on my 1990 bike, which has confirmed your observation. With the original s/a I used wider tyres and was able to ensure adequate tyre/belt clearance by using the individual belt tension adjusters. Having used the later s/a for awhile I have got the 'even wider tyre bug' (Deuce wheel with 160 tyre) and find the snail-cam adjusters are pulling the wheel too far over towards the belt. I have a couple of solutions in mind, including grinding back the left cam-stop.
