87 Octane A.K.A., Unleaded Regular
Old Aug 28, 2014 | 09:01 AM
Mr. Neptune's Avatar
Mr. Neptune
My tank holds 6 gallons, price difference between regular unleaded and premium will say is 30 cents. 6 x 30 = $1.80. Price of my new Harley $20,700. I will spend the extra $1.80 everytime I fill up.
Old Aug 28, 2014 | 09:59 AM
MNPGRider's Avatar
MNPGRider
Originally Posted by Keithhu
Not sure where you're getting your information, but factory compression is 9.6 or 9.7:1, not 8.5, BIG difference. Was it a typo on your part?
The '09 TC96 engines, which watchguy has (based on his sig pic), has a compression of 9.2:1 . TC88's have 8.9:1. It wasn't until 2012 that the compression went to 9.6:1 on the 103 engine. 2014's have 9.7:1, with the twincooleds at 10:1.
Old Aug 28, 2014 | 10:07 AM
Hausguy's Avatar
Hausguy
A couple of weeks ago I put in a tank of non-ethanol 87 and my bike didn't like it...started pinging. Next tank I went with 92 non-ethanol and the pinging was reduced but not gone. 3rd tank with 92 and I'm back to no pinging. Maybe that first tank was bad? I think I'll keep some octane boost with me from now on, but I'll stay away from the 87 if I can.
Old Aug 28, 2014 | 10:32 AM
tpcowfish's Avatar
tpcowfish
Neighbor accidently put 87 in his 12 limited, said it pinged horribly, scared the .... out of him, his bike is stock, but like stated above, maybe $1.80 a tank savings not really worth the risk. I can tell the difference in different gas stations , popping on decel ect.
Old Aug 28, 2014 | 10:42 AM
TWIN CAM 96's Avatar
TWIN CAM 96
Originally Posted by Veekness
Oh, goodie! A fuel thread! Seriously, Bikerlaw has it nailed...the other things to be aware of is one fillup of fuel means nothing...need to do it for a while...the first fillup contains a lot of the fuel that was in there.
I am in the habit of filling with 91 octane higher zoot fuel whenever I have the choice...Chevron with Techron is my first choice then Shell, Mobil, Unocal, and everything else after that...I'll run some Sea Foam thru, and some Startron, just for ducks...but if your bike runs good on the cheap stuff, yeah, do it, I'm not so certain that I, and everybody else running expensive stuff thru our bikes, aren't throwing our money away...
For me, I get peace of mind out of it, just like changing my synthetic oil every three thousand miles. The scientists will tell you that's a waste of money, time, and effort...but then again, I'm not a scientist...
I'll stick with Chevron 91 Octane myself that's what my bike runs best on but if not I'll run the others as Veekness does if Chevron isn't availalbe.
Old Aug 28, 2014 | 11:20 AM
Magnut1's Avatar
Magnut1
Look at it from this prospective. One of the guys posted the benefits of the detergent in premium fuel. Good point. Figure this. 5 gallon tank,, 10 cents more per gallon. 50 cents is cheap insurance for detergents and higher octane.
Old Aug 28, 2014 | 11:45 AM
danzio's Avatar
danzio
I run the best gas I can. If I can't find premium I will run mid-grade. A fill-up of 5 gallons will only yield a difference of 50 Cents or so. Why even consider this when gas prices will vary day to day. What you paid for premium yesterday is what you will pay for regular today. If you're gonna' sweat a 50 cent difference on a 200 mile tankful then you probably have bigger problems to think about.
Just my .02.
Old Aug 28, 2014 | 12:06 PM
m6zero's Avatar
m6zero
Just about to say the same thing...91 for me.
Old Aug 30, 2014 | 02:49 AM
Watch Guy's Avatar
Watch Guy
Default you're right
09 T.C's are in fact 9.2-1 not 8.5 as I said.
Old Aug 30, 2014 | 06:27 AM
Campy Roadie's Avatar
Campy Roadie
Let's see all those "I run 87 octane in my bike and there's no difference!" posts. That way when you try and sell your bike here, everybody will have a heads up
It's not just compression ratio that warrants the use of 91 or better, cylinder/head temps (higher on air cooled engines) and ignition timing. Can you get away with it? Sure, for a while. Colder ambient temps do reduce one element of the equation, but not all. Running low octane fuel in hot weather is asking for it. I know, I know; you live on the border in Yuma and it's 130 degrees F at 0600 hours and you've never run anything but 87 octane cut with water 50/50. Never had the first problem and the bike 380,000 miles on it. I call bullshit; that or you're deaf. I've ridden a Harley all over this continent and have had to use low octane fuel because there wasn't anything else (the Rockies, Mexico, Canada and northern Alaska). There is a difference.
A couple of guys have hit it on the head with some very good points, but here's the best one. A guy spends good money for a Harley, presumably he did a little research and found that it requires premium fuel; then he bought it. Now, after the deal is consummated he wants run fuel that isn't recommended but "lowers operating costs" because he saw a post on the internet from a guy who knows a guy who's 1st cousin is a bigwig petrochemical engineer at an oil company that he can't name. Anyway, this guy says that gasoline is gasoline and they're just selling you the same stuff no matter what grade you buy.
Run what you want in your machines. I buy and sell used bikes and one of the FIRST things I look for is signs of false economy legacies; that includes internet forum posts.
