Tuners and narrow band O2 sensors
Old Aug 29, 2014 | 07:43 AM
SavageChopper's Avatar
SavageChopper
Default Tuners and narrow band O2 sensors
When a bike is tuned using a PV, Screamin' Eagle, etc, what role do the narrow band O2 sensors play after the tune is done? I assume that their range is too small to be of use like the wide band sensors for Auto-Tune? For most tunes wouldn't they read too low? I've read different manuals, but I've never found an answer.
Old Aug 29, 2014 | 09:59 AM
TUCCI's Avatar
TUCCI
Don't know about the one's mentioned above, but my PCV doesn't use them at all and the motor runs real strong.
Old Aug 29, 2014 | 10:37 AM
SavageChopper
I have the PCV as well, but I'm thinking of moving to a PV and I believe the O2 sensors are hooked up with it. I just wonder what good a narrow band sensor would do in that case.
Old Aug 29, 2014 | 11:43 AM
Terryjft's Avatar
Terryjft
On several tuners, a "tuning mode" is loaded which puts the entire map in narrow band closed loop range. The tuner will use the sensor feedback to calbibrate the VE (Volumetric Efficiency) tables to your unique engine. This makes the math the ECM does for the AFR tables more accurate.
I have had a PV on my bike since putting 255 cams in last winter. I have used the FuelMoto canned map since then. This past wek, I just did get around to doing this "autotune" to the VE tables. It appears my gas mileage has gone up about 4-6 mpg as a result and throttle response seems a bit smoother.
Old Aug 29, 2014 | 11:46 AM
nhrider1's Avatar
nhrider1
The narrow band O2 sensors are used for autotune (basic). Autotune tricks the narrow bands into reading a much wider range than normal, and most people are satisfied with the results.
They are used after the tune to run closed loop tunes. You can't run closed loop without O2 sensors. Closed loop tunes provide good drivability and fuel economy for most people.
Old Aug 29, 2014 | 12:11 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
If you are using the factory O2 sensors with Auto Tune when you enter AT Basic mode the Power Vision sets the Lambda/AF targets near stoich (among other temporary edits) to allow the sensors to populate correction data within their useful range. When you then export the corrections and create a new map the Lambda/AF values revert back to the original target. Essentially once the ECM knows the specific airflow model (VE) it is able to mathematically calculate and deliver the desired AF. During normal operation (not Auto Tune mode) the factory O2 sensors are used in closed loop for adaptive fuel control. Hope this info helps
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
oleboy
19
Apr 4, 2016 08:09 PM
Rus103
Feb 24, 2014 10:06 AM
scotracy
Mar 9, 2012 12:36 PM
Rubbit
Mar 21, 2009 02:36 PM
GT_RoadGlide
Mar 4, 2009 12:28 PM
