Shifter Shaft Seal Leaking
Old Aug 31, 2014 | 10:10 PM
fxdxruss's Avatar
fxdxruss
This helped!
Old Sep 1, 2014 | 09:05 AM
onaride63's Avatar
onaride63
my bike was plagued with that seal leaking. Seemed to leak out of the seal, not the housing. I used after market seals and Harley seals....it took a layer of yamabond on the outer edge of the seal housing to correct it. 3 years and no issues......stock seal used . Make sure you shim out any free play in that shifter shaft. There suppose to be sorta tight. No shifting in and out of the tranny shaft bushing. to much and it wears the lip of the seal.
Old Sep 1, 2014 | 09:08 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Might want to check that bearing on the main shaft of the tranny. When the bearing goes it out causes the leak. Had two bikes have exactly the same thing happen. Fix it all now as opposed to a new seal now and then a new seal and bearing alter. Seems to happen around 50K on bikes.
I'd hate to see you put a new seal only to have the same problem a few months down the road. Made that mistake on one of my bikes.
fournierrandy
Aug 19, 2018 06:35 AM
trekez2
Dec 31, 2015 04:08 PM
GNrider
Sep 11, 2013 10:52 PM
Harley58
Aug 21, 2011 07:22 PM
timbo
Aug 28, 2007 09:53 PM
