Pull behind towing. Hitch Capacity
Old Sep 9, 2014 | 09:04 PM
Freebirdsride1's Avatar
Freebirdsride1
I would not go over 150 pounds total weight trailer and load. If you need to stop in a hurry the weight well transfer and left the rear tire from the ground.
Old Sep 9, 2014 | 09:27 PM
MNPGRider's Avatar
MNPGRider
I would challenge you to even find just a trailer that only weighs 150 lbs.
The tongue weight will push down on the back of your bike when braking, not lift it up.
Old Sep 10, 2014 | 04:40 AM
ddm502001's Avatar
ddm502001
Not true, watch any cage or even a tractor trailer in hard braking, the trailer looks to path of least resistance, will try to lift the back end as front end nose dives.
Brakes on our rides are designed for our rides and around 20-25% overkill for the engineered weight rate, we have all read the posts on warped rotors so adding 150# to the brake load will only create more heat and more damage. If you need gear to the level of need for a 3x3 or 3x4 trailer that can handle coolers, BBQ grills, tents, suitcases and so on you may need to rethink riding to a destination and tow the ride while stowing the gear in a car or truck. I am looking to a N-Line single wheel trailer, weighs in at 80# and can handle UP TO an added 80#, doesn't mean I can expect it to carry an additional 130# as that would be wasted effort and fuel as well wear and tear on the bike beyond that of adding a towed machine.
I ride to ride, and pack light, 4 to 5 days clothes/gear, no coolers, no excess weight items, I challenge the bike's systems by just being on it with the wife as I am not a small fella. A small single wheel trailer will move more so than add to our gear, the TP would empty, no longer would need a rack bag and can get the center of gravity back down low. We would be able to carry a few more days gear but not very much more.
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
My previous motorcycle cargo trailer weighed 40 lbs.
Many small trailers are built unnecessarily heavy, and a great deal of weight can be removed. Build one yourself and you can remove quite a bit more. For carrying a dirt bike, nothing more than a rail and an axle are needed.
Old Sep 10, 2014 | 03:44 PM
MConde85's Avatar
MConde85
Engine breaking combined with brakes??
Old Sep 10, 2014 | 03:56 PM
MConde85's Avatar
MConde85
Like this http://motorcycleinfo.calsci.com/Images/TrailerHF1.jpg
Old Sep 10, 2014 | 03:57 PM
MConde85's Avatar
MConde85
Thanks everyone for the reply.
Old Sep 10, 2014 | 06:34 PM
MNPGRider's Avatar
MNPGRider
Well, I concede that there are obviously trailers out there a lot lighter than 150 lbs.
But too little tongue weight causes sway....negative tongue weight would lift your rear when braking.
I stand by my post that positive tongue weight presses down on the hitch while braking, not lift it up.
And, you should never exceed the manufacturer's tongue weight recommendations, regardless of what "10-15%" of the total weight of the trailer is!
Old Sep 10, 2014 | 06:37 PM
MNPGRider's Avatar
MNPGRider
Originally Posted by MConde85
MConde85, please post the specs for that trailer you illustrate. I bet it is much more than 40 lbs.
Old Sep 11, 2014 | 08:02 AM
ddm502001's Avatar
ddm502001
There were engineering results out in the real world when I was a wrench in the trucking/equipment industry that supported the heavy braking rear end lift from trailers, unless you can maintain a absolute strait line to centerline of the drawbar and tow vehicle the tongue will lift the rear during severe braking. Almost all weight drives to the front wheel(thus our twin rotored tourers) while braking, in doing so drops/loads the front suspension and actually unloads the rear end, watch any ride at speed when they brake, the rear end raises, cars/trucks will actually break loose at the rear first from that unloading so I cannot see a variance to the physics at this date for bikes.
You place that much weight behind one of our bikes and it is going to push you where it directs, not where you may expect.
