Wood 400-6 Cams
Fitment: 06 Dyna, 07-14 Twin Cam
Part#
.053 Timing
Duration .053
Valve Lift
Lift TDC
Springs
Application
TW-400-6
22/42
42/20
244
244
.650
.650
.210
.190
HI-LIFT
Maximum Torque, 2000RPM & Up
Bolt-In for SE Ported & 103+ Heads
The "Knight Prowler" Cams are designed by Wood Performance Carburetors, and are custom manufactured by Andrews Products to exact Wood Performance specifications. These special KNIGHT PROWLER STREET Cams feature Short Duration, High-Lift specs that are a trade mark of Bob Wood. They yield Very High torque and horsepower numbers, not matched by any other cams at this time. Our philosophy is basically the same that we used to achive two NHRA national records. IT'S NOT HOW FAST YOU GO… BUT HOW QUICK YOU GET THERE! TORQUE, TORQUE and MORE TORQUE is the ONLY way to put you there quicker and to "Smoke the Competition!" This design and manufacturing process has produced The Most Advanced, Aggressive camshaft profiles for H.D. Evo and TC88 Engines available anywhere!! Special Note: These KNIGHT PROWLER camshafts are designed specifically for Street and Touring bikes.
