I have a brand new in the box Biketronics BT454Amp kit. Comes with amp and all wiring needed for install. $300 B/O. !!!!!!! PLUG AND PLAY !!!!!!!!!
At roughly 1.5 in. x 3.25 in. x 4.25 in., the Biketronic Titan 75 watt RMS (per channel) stereo amplifier is the smallest, most powerfull mobile amp in its class
Titan will transform your motorcycle audio experience with more teeth-clinching, high quality sound than you will ever need
Famous Plug-N-Play design using factory connects
Ten minute install (excluding fairing removal)
Simple single piece water resistant-design-No barrier terminals to connect or corrode
No wires to pull to battery
No satellite units to mount
Protects your charging system with Biketronics StatorGuard technology
Famous Biketronics Reliability (lifetime warranty)
Works on most touring bikes
Reason: Lower Price
