Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
TTS File Download Recommendation
Old Jun 24, 2015 | 05:15 PM
PopDukes's Avatar
PopDukes
Default TTS File Download Recommendation
Hi All,
Hoping I can get some help? Have a 2009 Tri-Glide, Stage 1 AC, V&H Slash Cut Slip-ons and recently had Kuryakyn Tru-Duals (I understand the same as V&H Dresser Dual) installed. All else is stock. The map someone uploaded causes allot of back fire when decelerating and between gears sometimes, and appears lower compression? Even heard a pop a couple times when accelerating?
Can anyone advise either from the Kuryakan website or Mastertune website or any other site, which may be the best file to try and upload?
Sadly, the closest Dyno for my Trike is in Reno which is 400 miles away. I am in Los Angeles.
Thank you in advance for any help you can provide.
Pops
Old Jun 24, 2015 | 05:21 PM
sprinkman's Avatar
sprinkman
Lots of good people here someone will chime in just give them a little time.
Old Jun 25, 2015 | 07:22 AM
Mr. Wizard's Avatar
Mr. Wizard
Use the DAC205-04.mt9
Then VTune to set your VE tables. You can follow the link in my signature to tune but it was for the last version of VTune. Everything else is the same so just follow the directions.
You will not find a calibration for your 2009 with duals that is any closer than the TTS calibration above.
Old Jun 25, 2015 | 10:23 PM
PopDukes's Avatar
PopDukes
Thanks Wizard. Have downloaded your pdf.
Old Jun 26, 2015 | 06:04 AM
Mr. Wizard's Avatar
Mr. Wizard
Also... you know TTS is located in Compton?
You can always swing by and say hello to Vicki and Steve.
CaptKirk
May 19, 2015 04:35 PM
Louis_Dobson
Sep 16, 2012 12:38 PM
jfsimi
Aug 15, 2010 04:27 PM
cornholio
Jun 30, 2010 12:42 PM
FrankT
Oct 7, 2009 09:08 PM
