Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Trunk will not open
Old Jul 7, 2018 | 05:27 PM
GPHDXLC's Avatar
GPHDXLC
Default Trunk will not open
My wife 16 Freewheelers trunk wont open. The bike has been trouble free in every way, until now. Warranty just ran out 3 weeks ago. The handle turns like normal but it wont release the latch. Took it to the dealer and he said they will need it for a week. They will need to take the wheel off and the fender then cut a hole in the trunk for access to the latch to open it. Then fix what ever is wrong with it then patch fiberglass over the hole then put it back together. I'm going to call him this week for the cost. He said they will help me on the cost.
I wish the MoCo would had made them with a access hole with a plug in it. I cant think of any thing different to do the fix it my self. No way in hell it will open as it is....Any one ever heard of this on Freewheelers ??.
Old Jul 8, 2018 | 06:52 AM
santajim's Avatar
santajim
Before I would let them cut on your bike I would find a good locksmith and see if he can do anything. There has to be a way to get that open without cutting holes in your bike.While turning the handle back and forth lift up kind of hard and turn maybe it will engage the latch again.
Old Jul 8, 2018 | 06:56 AM
Notgrownup's Avatar
Notgrownup
This....^^^^^ Even if you have to drill out the latch and get it like that, buy a new trunk latch... sounds like catch got loose inside and is not turning...play with it back n forth tons of times, maybe it will catch, tap it with a hammer lightly while doing this...
Old Jul 8, 2018 | 07:01 AM
bronxbill's Avatar
bronxbill
There was a thread on this a couple of years ago; if you search you might be able to find it. As I recall, the screws holding in the latch backed out and caused the problem. I believe there were some solutions that did not involve cutting a hole. Sorry I can't remember more.
Old Jul 8, 2018 | 11:45 PM
sloufoot's Avatar
sloufoot
Might be of some help:
https://www.hdforums.com/forum/tri-g...cked-shut.html
Old Jul 9, 2018 | 06:22 AM
GPHDXLC's Avatar
GPHDXLC
I've seen all the Threads and we and others have tried every thing under the sun to try and open it, "nothing works". The MoCo did not make any back way to get inside. If it was the lock in the handle it can be opened. Most of the time the cable running over the the latch disconnects. My research .shows that cutting in from the side is the only option. Our Freewheeler has been a perfect bike. Had I known about this issue I would had lock tight the bolts
I don't think my dealer is Fuc*** us over, A lot of people have had to do the same thing.
This sucks but I cant find another way out.
Old Jul 9, 2018 | 03:31 PM
ord sgt's Avatar
ord sgt
After reading this post, I had to check on the trunk latch of my 2016 FLRT. Looked in the manual, and found the inch/pound torque settings. Set the inch/pound wrench and found every screw was loose. Both on the lid and the catch. Tightened everything to specs. Just another thing to periodically check on. But at least it will open and close with no problems.
Old Jul 9, 2018 | 07:09 PM
GPHDXLC's Avatar
GPHDXLC
Angry
I checked everything on her bike but never thought of the trunk.
Old Jul 13, 2018 | 07:54 PM
GPHDXLC's Avatar
GPHDXLC
It's open and fixed. Dealer wanted to spend 3 to 4 hours on it. Took it to my Indy and he got it done for $100. And now I have a plug behind the fender if any thing stupid like this happens again.
Old Jul 16, 2018 | 08:40 AM
fmgsr's Avatar
fmgsr
Real nice, and the dealer wanted to hold it for a week. Did you ever get an est. cost from the dealer?
