Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tri Glide Reverse
Old Jul 24, 2019 | 07:41 PM
Squan5's Avatar
Squan5
Stage I
Default Tri Glide Reverse
Reverse quit working. Manually opened and closed the reset
breaker. When reverse is engaged I hear the breaker clicking but not tripping.
Old Jul 25, 2019 | 12:59 PM
SPRINGER's Avatar
SPRINGER
Just wanted to let you know that we do have a Tri Glide section on this forum where you might get more info on your problem.
Old Jul 25, 2019 | 03:17 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
Moved to the TriGlide section.
Old Jul 25, 2019 | 06:32 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
There are several threads on that here, scroll back or search. You're hearing a reverse relay, not the breaker, but the starter itself isn't engaging.
Old Jul 26, 2019 | 03:16 PM
SpringerRider's Avatar
SpringerRider
I had the same and took it to my dealer. I swore I had re-set the breaker but I did not close the little red-lever enough.
Old Jul 26, 2019 | 05:01 PM
470004's Avatar
470004
Thanks for the video.
Old Jul 29, 2019 | 02:06 PM
FLHXLNOW's Avatar
FLHXLNOW
I started having trouble with my reverse this season. Sometimes it moved really slow, sometimes not at all, and yet sometimes it worked as usual. While checking things out about two weeks ago, I wound up with the reverse not moving the motorcycle, and not being able to get it "out" of reverse either. So, no movement forward either as you couldn't get into a forward gear. I could hear the relay click but it didn't do anything. The dash mounted voltage meter would also drop to 8 volts when the reverse button was pushed after the initial push to prep it for use. Finally managed to get it out of reverse and taken to a Harley shop for service. Reported to be a bad (malfunctioning) solenoid on the starter motor used for reverse. Cost almost $430 to get it fixed. It was explained to me that until fairly recently the only fix Harley had for it was total motor replacement for about $1300.. I'm sure that someone more mechanically inclined that me could probably have fixed it for a whole lot less money. Hope this isn't your problem.
