Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
handlebars
Old Sep 19, 2019 | 11:57 AM
dmvcdl@gmail.com's Avatar
dmvcdl@gmail.com
Stage IV
Default handlebars
want to change handlebars how hard is it to replace them?i am 6 2 and these stock bars are killing me after reading reviews i want to get the harley batwing tall boy.
Old Sep 19, 2019 | 12:17 PM
kwkride's Avatar
kwkride
Not too bad. It took me about 2 1/2 hrs to change mine out and add heated grips. You'll probably want to have the factory service manual handy,
Old Sep 19, 2019 | 05:34 PM
Mr. Wizard's Avatar
Mr. Wizard
Yup... that's about what it takes and a bucket load of patience.
Oh... if you want your username changed from your email address to something else send me a PM.
Old Sep 25, 2019 | 09:38 AM
RCUltra's Avatar
RCUltra
I did a set of Krome Werks wide sweepers with internal wiring in about 2 1/2 hours. Not a hard job. HD dealer quoted crazy numbers saying the internal wiring was a nightmare. It took around 15 minutes to pull both sides through.
Old Sep 25, 2019 | 04:39 PM
Pvt93's Avatar
Pvt93
4th Gear
What year bike do you have? I just picked up a 2019 and want to put the Wide Sweepers on mine and need to know if I will have to get the wire extension or not.
Old Sep 25, 2019 | 04:49 PM
RCUltra's Avatar
RCUltra
It's a '19. I did the extensions. It would work without if you go external, but if you go internal, you'll need extensions for the switch wiring. Throttle is fine and you'll have to reroute the brake line a little. I went with 300517. They fit like a glove.
daurwid
32
Jun 11, 2022 01:51 PM
Ryanmmhay
Jul 11, 2019 01:46 PM
Hot Rod King
Apr 27, 2011 11:15 AM
blackswampbiker
Nov 7, 2010 08:20 AM
vettedog72
Feb 20, 2008 10:10 PM
