Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Stock paper A/C filter any good?
Old Oct 23, 2020 | 05:00 PM
Mr.Softy's Avatar
Mr.Softy
Default Stock paper A/C filter any good?
Just bought a breather kit from DK. While watching the video on installation I got to thinking about the stock paper filter and if there was any advantage to changing it out? Are the replacements better and or do they allow more air flow?
Old Oct 23, 2020 | 05:31 PM
470004's Avatar
470004
I have the Harley's Stage I set up on my bike.
Old Oct 24, 2020 | 05:51 PM
Mr.Softy's Avatar
Mr.Softy
So I shouldn't change the filter out for a K&N because that will make it even more lean? Wait until I am ready to add a tuner?
Old Oct 25, 2020 | 11:04 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
M8's do Not have the lean problem that Twin Cams have. They are Not too lean in factory tune, Plus you can add a free flowing air cleaner to them and the ECM will adjust so they are not running too lean.
There is a Report on this subject, with AFR readings at this LINK.
That said, a M8 will run better with an optimized tune, But it is not dangerously lean like the Twin Cams, so there is no problem going with a free flowing air cleaner without changing the tune.
When looking at a Free Flowing air cleaner, there is more to it than changing out the filter element. Many folks put a filter element in their air cleaner, then go on and report that they saw little to no performance improvement. That is because there are 4 factors that are equally important in the differences between an chocked OEM set up and a True Performance air cleaner.
1. Free flowing filter element
2. EBS..only clean, cool, oxygen rich air going in
3. Get rid of the EPA conforming HOT Box that the filter is sitting in
4. What happens with the air AFTER it goes thru the filter element. The internal design of the air cleaner can significantly affect HOW the air flows, AFTER passing thru the filter element. It should flow quickly with the least turbulence.
Below is a video that talks about some of the above-
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Oct 25, 2020 | 11:36 AM
Mr.Softy's Avatar
Mr.Softy
I ordered the EBS system from you it should arrive this coming Tuesday. That led me to ask about the filter element. I like the stock A/C cover and would like to keep that look. I have 9 months left on my warranty and am not ready yet to add a tuner.
Old Oct 25, 2020 | 11:53 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Here's a photo of a Performance air cleaner that does not need a tuner and utilizes the stock cover-
More photo's & details of this air cleaner at this LINK
Give the shop a call or email about it to get an adjustment, since you already have a breather system.
Old Oct 25, 2020 | 12:44 PM
Mr.Softy's Avatar
Mr.Softy
OK I like the 606 A/C kit. I have put it on my priority list for next month. Thanks
Rem
Oct 2, 2020 09:01 PM
PSU
Milwaukee Eight (M8)
Nov 15, 2017 07:51 AM
MachU
Aug 15, 2013 07:50 AM
sioux565
Feb 21, 2012 07:55 AM
de79
Jan 2, 2011 11:09 AM
