Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tie down brackets
Old Nov 19, 2023 | 10:09 AM
PopsHD's Avatar
PopsHD
Default Tie down brackets
I had the HD tie down brackets on the forks of my 2014 Limited. Seems these, nor any other brand I've found, will not work on the trglides. Anybody know why they don't work? Do you have front tie down brackets on your triglide? Thanks!
Old Nov 19, 2023 | 10:17 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Not sure why they will not fit/work.
I use soft shackles around the lower fork leg, right above the fender mount point.
Here is a video-
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Nov 19, 2023 | 10:23 AM
PopsHD's Avatar
PopsHD
Here is a video-
https://www.youtube.com/watch?v=gzbKysq1ymc
Yep that's how I tie down now but really liked the brackets. Thanks!
Old Nov 19, 2023 | 10:30 AM
Notgrownup's Avatar
Notgrownup
I don’t like the tie downs on my Tri …I like to use the soft ties around the fender bracket as well. I used the tie downs but only as a redundancy.
Old Nov 19, 2023 | 10:41 AM
PopsHD's Avatar
PopsHD
What tie down brackets do you have? Thanks!
Old Nov 19, 2023 | 10:57 AM
Notgrownup's Avatar
Notgrownup
None, I had Kuryakyn on my Electra Glide but not on my last 14 or current 21 trike. I just towed my 14 to Canada in August and it did fine. Have some D rings welded on the front of my trailer and recessed foldaway hooks in the back of the trailer floor. I bought ratcheting tie down straps with the spring clip to prevent the from coming off.
Old Nov 25, 2023 | 08:02 AM
Rogue1's Avatar
Rogue1
I tried putting tie down brackets on my TG. They will mount on the right side but the way the steering stabilizer mounts on the left side keeps the bracket from sitting flush underneath the driving light mount.
I hoped I described in a way it makes sense.
XFXDX
Feb 14, 2014 07:05 PM
Lama
Nov 2, 2011 09:50 PM
El Chiguete
Apr 15, 2010 08:27 AM
chop09
Mar 11, 2009 01:29 AM
kpb46
Jul 17, 2008 11:15 PM
