Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Jackpot Question
Old Jun 12, 2010 | 02:33 PM
ELR's Avatar
ELR
6th Gear
Default Jackpot Question
I have the Jackpot Header on order for my 2010 Tri Glide. I have installed 255 Cams, SE Stage 1 Air Cleaner, SE Peo Performance Mufflers, and HD's download. My dealer thinks that the HD download should handle the new headpipes. What have the forum members done? Or should I order a PC-V to install? If I order the PC-V should I also order the autotune?
Thanks for your input.
Old Jun 12, 2010 | 04:14 PM
coupe55's Avatar
coupe55
Default Pc-5
I hear 2010 Dealer Maps are still lean but they are others that can speak to that better than I.
With the PC-5 from Fuel Motto you tell them your mods and they load it up before shipping, will just cost for the Map later on if you do more mods.
One stop shopping and they won't be worried about dumping to much fuel on the Cat and ruining it over time!
Old Jun 13, 2010 | 01:02 AM
msocko3's Avatar
msocko3
Like coupe55 said the Harley download is lean in a lot of places and could use improvement. I'm running a combination that is pretty close to what your running now, including the mufflers. I have the Jackpot headpipe and I have used the SEST to tune mine and have gotten good results. My gas mileage has improved over what it was before I made the changes, it runs cooler and the power is much improved. I don't have any real experience with the PCV, just what I've read. If your looking for a quick solution and you don't have a dyno that can handle a trike available then the PCV is a good solution. I'd talk to the folks at Fuelmoto as to whether the Autotune is for you or not.
VTGlideRider
Jan 3, 2011 02:51 PM
02Flstfi
Sep 10, 2010 10:53 PM
Maggie
Sep 27, 2009 02:00 PM
woosh
Aug 7, 2009 12:26 PM
jcanrun
Jun 6, 2009 07:20 AM
