Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Front mudflap
Old Feb 18, 2011 | 02:25 AM
kookie 696969's Avatar
kookie 696969
Default Front mudflap
Looking for some input about installing a front mudflap, i live on a dirt road and dont want to beat the hell out of it with rocks, sand, and mud. Is there a good bad or other mudflap to put on it and is there any issues with the air flow to the cooler . thanks ken
Old Feb 18, 2011 | 04:56 AM
oldmsocko's Avatar
oldmsocko
Here you go. http://www.timberwolfleather.com/cat...-MUD-FLAPS.htm. I used the Harley FL Front Fender Skirt and I am very happy with it. I don't believe that it causes any negative air flow conditions.
Old Feb 18, 2011 | 03:33 PM
aslater's Avatar
aslater
1st Gear
Default Front Mudflap
I purchased a rear mudflap for a Roadking....it comes with an internal bracket. You remove the front skirt bend your bracket to the shape of the skirt. The bracket has mounting holes in it....mark and drill the skirt for the bracket holes. Remount the skirt and attach the bracket and mudflap to the skirt with the mounting screws that come with the kit. You will need to pay attention and set the top of the flap as close as possible to the bottom edge of the fender as possible. WALLA you now have a front mudflap. I did this on my '03 RDking it was on there for 5+ years and worked perfectly. As soon as I got my Trike I did the same thing. You need to make sure the rear mudflap you purchase is the same width as your front fender.....I beleive the 10's rear is wider than they used to be, but the front hasn't changed. I purchased a rear mudflap for a '03 and it worked fine.....Good Luck. By the way the clearance between the tire and fender on the trike is real close so if you have large hands it's a tight squeeze.
Old Feb 18, 2011 | 04:05 PM
TheJimer's Avatar
TheJimer
works great!
Jim
Old Feb 18, 2011 | 04:20 PM
41inWV's Avatar
41inWV
Ordered mine should be here by Monday
Old Feb 18, 2011 | 07:18 PM
oldmsocko's Avatar
oldmsocko
You will be very pleased with it.
Old Feb 19, 2011 | 06:48 AM
Boom's Avatar
Boom
Mike, have you got a picture with that flap on your fender? I'd be interested to see what it looks like.
Old Feb 19, 2011 | 07:11 AM
icebite1's Avatar
icebite1
I would sure like to block the road junk from the oil cooler but am still leery about air flow.
Old Feb 19, 2011 | 09:12 AM
oldmsocko's Avatar
oldmsocko
I'll take one today and post.
Old Feb 19, 2011 | 01:43 PM
Boom's Avatar
Boom
I just took a look at my original oil cooler and noticed paint gone from the center area. I'm ordering that mud flap! Thanks for the info!
