Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Oil in Air Filter
Old Jun 18, 2011 | 03:20 AM
msocko3's Avatar
msocko3
Originally Posted by paw paw willie
Put 3000 miles on bike in past week. "Misting" is pretty bad. "Misted" 1 qt. Took off curved vent hoses and put on longer hoses routed to under engine. No more problem with oil on me and bike but underside of bike is dripping oil from "misting". This is crazy. Really thinking of plugging vent ports. Can anyone see a problem doing that?
If your loosing that much oil out the breathers there is a problem, they shouldn't do that. Some of the causes can be excess blow by from poor piston ring seal, sumping which can be from poor oil pump alignment or something wrong with the 2nd stage of the pump, or something restricting the oil flow back to the lower end. The best thing you can do is put the hoses back the way they were and take it to the dealer and tell them its not normal and if they don't want to hear it then call Harley customer service. If you plug those ports your going to pressure up the engine and cause gaskets leaks or worse.
Old Jun 19, 2011 | 06:17 AM
tbob's Avatar
tbob
I am having the same issue. I am losing about a half quart every 3,000 miles.
this only started when I went to the stage one filter. dealer claims its piston
ring gap on the rings and is normal. I just carry a rag and wipe the breather out.
Old Jun 19, 2011 | 07:04 AM
oldmsocko's Avatar
oldmsocko
That's typical of HD saying that. I don't believe that for a minute that it is normal.
Old Jun 19, 2011 | 08:27 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
I assume you think its all going out the breather system. If this is the case like the FP you indeed have a problem in the breather system. However it's not the breather itself. Like I have said the poppet valves in this system are out going. The problem is something is over welling the system. Either a failure of the oil to get out of the engine. (clogged return port 33, oil pump, foreign particle in the return hole 19 in the head) or (piston ring problems with blow by) Do not think a 1/2 qt in 3000 would even show on the spark plugs) It can have blow by and still have oil control in the cylinders if something is broken.
My bike with 40K will have a drip from the stage one on there now especial if I let it sit a few weeks with out use but it consumes little oil. The SYN3 is near the top on the stick and it has 3164 miles on it. Changed it 6/15/10 .
Old Jun 19, 2011 | 01:21 PM
msocko3's Avatar
msocko3
They need their head examined, shows they don't know much about the product their servicing. I have yet to loose much of any oil in 5,000 miles, I'm sure I loose a slight amount but I can't see much of a change on the dip stick. I can say the same goes for my dads Trike because I service it, he doesn't use much of any oil in 5,000 miles either. I have the SE Ventilator air cleaner and my dad has the SE Stage 1 air cleaner. For the most part I may find some moisture in there with a little oil residue but nothing drips.
The last bike I had which dripped was a 2005 Electraglide Classic with a Stage 1 air cleaner on it. The bike had around 3 or 4,000 miles on it when I started getting drops of oil on the cam cover. I took it to the dealer and the service manager said it wasn't normal and they would see what was wrong. Turned out to be oil pump alignment was off, they aligned it and I never had another drop after that.
Old Jun 20, 2011 | 03:00 PM
tbob's Avatar
tbob
Thanks to all for the reply. Took it to a diffrent dealer, Got the call today and it has
the oil pump out of alignment.Maybe you guy's should open a dealership. Thanks to
all for the help.
Old Jun 20, 2011 | 03:04 PM
Boom's Avatar
Boom
all for the help.
Let us know if that definitely fixes it. I'd be curious to pose that question to my dealer since they say "they all do that".
Old Jun 20, 2011 | 03:23 PM
oldmsocko's Avatar
oldmsocko
Boom: I can tell you I have owned 4 new Harleys in the recent years and none of them used oil.
Old Jun 20, 2011 | 03:42 PM
Boom's Avatar
Boom
Me too Mike. And this is the first model for me that ever blew oil out the filter.
Old Jun 20, 2011 | 04:26 PM
NickD's Avatar
NickD
When Harley was forced to finally seal their V-twins so they were oil leak free (which began with the Evo motor) the last problem they had was what to do with the piston blow-by oil, the oil used to lubricate the rockers in the heads, and that mix of oil and water (from condensation) that makes that milky brown sludge. The main problem is the return oil system from the heads just isn't effective enough.
They could have designed a catch system you have to empty occasionally but spread across all model bikes that would have been too expensive. So they used the band-aid approach. Shove it all into the intake system to (supposedly) be burned. It made the EPA happy but think about what that oily stuff does to a carb, or an EFI system, and your spark plugs.
And no, you shouldn't seal the head breather holes to stop the leaks and misting. The fact the mist comes out from there is telling you the return oil system isn't up to the job of relieving all the head pressures. Sealing these holes would probably result in gasket leaks elsewhere.
The best fix is either (if you're Green) build a catch can system, or otherwise just run both head breather hosed into one hose that drains to the ground.
The amount of oil in the oil tank does matter, but it's more about the amount of empty space above the oil level in the tank. These oil tanks really need to be vented to outside air pressure but Harley was loathe to but another hole in the system that could leak oil.
Harley may never solve this problem without ditching the current push rod setup. And I think most of us are glad they haven't changed to an overhead cam setup for traditional and aesthetic reasons. But if you ever owned a Shovelhead motor this misting problem on Evos and TCs isn't really that big a deal . . . until you have to clean it up, LOL!
