Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Changes since 2009
Old Mar 15, 2012 | 08:25 PM
Wreckman's Avatar
Wreckman
Default Changes since 2009
Looking at a 2009 TG but wondering what Harley has changed form 2009 to 2012. I know there is a gearing change. What else?
Old Mar 15, 2012 | 08:37 PM
RAP's Avatar
RAP
Well, I think the 09 did NOT have the cat in the header. The 10 on up do.
Old Mar 15, 2012 | 09:18 PM
TheBobs's Avatar
TheBobs
A much much better designed trunk door. Better gearing: 30T front sprocket versus a 32T.
Old Mar 15, 2012 | 09:21 PM
TheBobs's Avatar
TheBobs
The side panels on my '12 seem lighter constructed than the one on my '10.
Old Mar 16, 2012 | 12:15 AM
msocko3's Avatar
msocko3
Only CA emissions equipped 09's had a converter, 2010 and later have them on all 50 state modles. Starting with the 2011 modle they switched to a 30 tooth transmission sprocket, moved all assembly to the York PA facility, made several changes internal on the engine along with a redesigned throttle body. The 2012 MY has a few minor mechanical changes, nothing earth shattering.
Old Mar 16, 2012 | 01:00 PM
Rox's Avatar
Rox
I know they did change the transmission 5th gear in 2010, you could hear 5th in 2009 touring bikes. Of course, the paint colors....
Old Mar 16, 2012 | 04:28 PM
screwball's Avatar
screwball
My '09 (California Cat) has a noisier 1st gear than wife's '11, also the reverse relay and 'stuff' were relocated to the right side cover. Pretty much ride about the same. Wife's seems a bit faster, probably the lower primary gear and the fact that I'm 100 pounds heavier. AND she does have a "lead wrist"
jwlehman
Jan 18, 2009 01:45 PM
bikejocky
Aug 8, 2008 08:43 PM
bobad24
Jul 22, 2008 01:30 PM
07Fatty
Jul 10, 2008 02:33 PM
harleyrobert4
May 3, 2008 11:20 PM
