I have read, looked at the pixs,and pushed all the buttons and I still don't get it. Help please..
How is the FM/AM radio turned off and still use the intercom? I have the radio
volume turned down as low as it goes and wife claims she can still here the radio in her headset. I can't! I can't turn the radio off. I just want to use the intercom and have the radio turned "OFF"... Can it be done? Thanks,
Terry in Tn
2013 TG
Thought I would mention I problem I recently had with radio. I couldn't determine why the radio kept cutting out. Seemed to be hit & miss, no pattern. Started switching out buttons, checking connections. Turns out the squelch was on low on the CB. Whenever I would get static, the radio would cut out thinking the CB activated. Raised squelch and problem solved. $ & time later!
