Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
No Reverse
Old May 15, 2013 | 11:46 AM
redroc223's Avatar
redroc223
Stage III
Default No Reverse
Guys
Tried moving her yesterday light will come on orange, turn to green, sounds like it engages and then will not move? I know there is a reset and a fuse correct.
Can someone tell me where they are located so I don't have to dig the book out....
Thanks
Tara
Old May 15, 2013 | 11:58 AM
flagirl's Avatar
flagirl
If I remember correctly, on the right side, just beneath the seat (you don't need to remove the seat), there's a triangular shaped panel that can be removed. The breaker for the reverse is found under there. It will look like a plastic rectangular switch that popped out. Just push it back in and if that was the problem, you should be good.
I'm not sure exactly where the fuses are located, however.
Old May 15, 2013 | 12:43 PM
redroc223's Avatar
redroc223
Stage III
Thanks I am going to look for that when I get home
Old May 15, 2013 | 06:18 PM
BinIdaho's Avatar
BinIdaho
Fuses are on the left size behind the "triangle" panel that comes off just like the one on the right size.
Old May 16, 2013 | 06:03 AM
msocko3's Avatar
msocko3
The breaker for reverse on 2009 Triglides is located under the seat, starting with the 2010 MY to present it is located under the right side cover.
Old May 16, 2013 | 06:50 AM
oldmsocko's Avatar
oldmsocko
Ditto what Msocko3 posted.
Old May 16, 2013 | 06:58 AM
icebite1's Avatar
icebite1
Redroc, you didnt tell us what year it was so it can be either of 2 different locations for fuse/breaker as mentioned.
If it sounds like its engaging I doubt its the breaker because if the breaker is triped you wouldnt get any power to the reverse motor so no noise.
Take a look under the rear end and see if the reverse motor is loose or worse case in pieces such as in pic.. This was a problem on several early models
Harleygirl81
Mar 29, 2015 11:07 AM
jm04
May 23, 2009 09:43 PM
capt42a
Jun 14, 2006 09:38 AM
