I'm thinking of getting the cb module for my new 2014 Tri.
Has anyone installed the module and is it pretty simple to do? I usually do my own work on my bike so I think I should be able to tackle this.
Also, The new T/Gs come with a cap over the hole where the PTT button should be. I found a part number for the button. Is the wiring for the button under the switch assy?
Haven't done that but have heard reports of the antenna and cable not being sent with the CB kit... just a heads up. Might want to double check and make sure they order that too.
