Twin Cam Motors Twin Cam 1998 thru 2017
TC88 Motor Swap
Old Mar 8, 2020 | 12:06 PM
Cruizer40's Avatar
Cruizer40
Default TC88 Motor Swap
Do you know if my 2003 Heritage Softtail motor can be swapped out for a 2006 model?
Thanks
Old Mar 8, 2020 | 02:12 PM
Max Headflow's Avatar
Max Headflow
Thanks
As long as it's a 06 softail motor, yes.
Old Apr 12, 2020 | 02:13 PM
Driver-60's Avatar
Driver-60
2nd Gear
In the same vein..... I have a 2000 RK MMEFI i just found a brand new zero mile 2016 103 a motor. i know its going to need a zippers conversion,but what about Cam and Crank sensors?
Old Apr 12, 2020 | 04:46 PM
Max Headflow
A 2016 motor won't fit in a 2000 bike unless you include the transmission and primary.
Old Apr 13, 2020 | 12:17 PM
Driver-60's Avatar
Driver-60
2nd Gear
nutz! i want a 103 Road King but i just cant finance 15+k right now. I guess I ride till it dies, Probably crazy to rebuild
Old Apr 25, 2020 | 06:10 PM
Jhensley's Avatar
Jhensley
Stage II
Default 06
to 16 so a complete drivetrain eng primary and trans would fit a 06. Both would be touring.
Old Apr 25, 2020 | 08:01 PM
Max Headflow
While I've not done it some here have. The only thing that I would check is clearance on the left swingarm mount and primary. You should be able to use one off an 07/08 bike. Other than that it should drop right in.
cracker318
Dyna Parts
Mar 1, 2017 08:17 PM
LouBit01
Nov 22, 2013 03:25 PM
El Chiguete
Exhaust System Topics
Mar 28, 2011 07:22 PM
El Chiguete
EVO
Mar 28, 2011 07:21 PM
gnccer150
Touring Parts
Apr 21, 2010 03:13 PM
