Twin Cam Motors Twin Cam 1998 thru 2017
Compensator changes for 2014
Old Aug 21, 2013 | 09:05 AM
Def Mute's Avatar
Def Mute
MoCo's recall strategy...
Don't recall anything. Make design changes on future models, and sell them on the idea that recalls are not necessary in Harley World. Don't forget...
Harley Davidson is a LIFESTYLE!
Old Aug 21, 2013 | 09:08 AM
btsom's Avatar
btsom
Do they say what size that Torx head bit needs to be? My biggest is a 50. Is a hex head too "old school" for them this year? Probably one more high $ special Harley tool now.
Not much I could do about the width of the cam faces, but I did some of that stuff to my SE comp several years ago and it is still doing very well. It still looks to me like the smooth, uninterrupted faces on the sprocket hub will "lock out" any oil to the hub. That will remain a problem area until the next version. I put three radial grooves on each side of the hub at the base of the spokes and connected them internally with a spiral groove leading to the next adjacent face groove on the opposite side. So far, so good.
Old Aug 21, 2013 | 09:19 AM
tOSUSteve's Avatar
tOSUSteve
Says in the one picture it is a T-70
Old Aug 21, 2013 | 09:22 AM
kykurnal's Avatar
kykurnal
subscribe...
Old Aug 21, 2013 | 10:18 AM
Arizona's Avatar
Arizona
The compensator is the only problem I've had with this bike. It's been changed twice now under warranty. It's the weak point in at least the '09s. Not sure what other year models (maybe '07 thru '13?).
Glad to see this has been addressed.
Old Aug 21, 2013 | 10:26 AM
Wild Card's Avatar
Wild Card
There are no problems with any of HD's engineering to require call recall's...most parts fail outside of factory warranty. sarcasm and serious at the same time
Old Aug 21, 2013 | 10:46 AM
TWIN CAM 96's Avatar
TWIN CAM 96
It said it takes a Torx 70 bit
Old Aug 21, 2013 | 01:01 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Torx type fasteners are really becoming popular.
Old Aug 21, 2013 | 01:38 PM
Guntoter's Avatar
Guntoter
According to the design of the new compensator, it uses that type of bolt since there are oil holes drilled through that "nut" to get oil inside the bore of the sprocket. The bolt head is tapered to allow that so a Torx is probably the best type of bolt for that.
Here is the new compensator upgrade. Note that it does not come with the rotor, that is a separate purchase for '07-'10 bikes (that do not already have the SE comp.) There is an adhesive that has to be bought separately also.
http://www.harley-davidson.com/store...mpensator#tabs
Old Aug 21, 2013 | 01:45 PM
Lowcountry Joe
Went to that link but it looks like it's missing a few parts according to whats new on the 2014s in the photos.
