VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
belt squeel!
Old May 19, 2007 | 01:42 AM
so cal 450's Avatar
so cal 450
Default belt squeel!
What would cause my belt to squeel?It only happens on deceleration.I installed a Hogpro 240 kit myself.
Old May 19, 2007 | 08:22 AM
Max's Avatar
Max
Default RE: belt squeel!
Often chrome in pulleys especially new pulleys will make noise. You can change the tension on the belt, or even use light oil or lube on the belt to see how it does. I used powder graphite on the belt when I put my weld wheels on and it worked good until you washed the bike and then I would have to apply it again. After a while the belt broke in to the new chromed pulley.
Old May 19, 2007 | 10:03 AM
eazy's Avatar
eazy
Max is right, it's probably just not broke in. My belt squeeled like a stuck pig for a while but after it was run for a while I've never heard it again.
Old May 19, 2007 | 02:02 PM
so cal 450's Avatar
so cal 450
Thanks guys,now i can get back to ridin worry free.How important is it to use a tension gauge?or is guessing & using my finger good enough?
Old May 19, 2007 | 02:51 PM
eazy's Avatar
eazy
The manual says to avoid using an estimate because most often the belt is under-tightened and causes failure of the teeth. I use a belt gauge and would recommend it. They're a whole lot cheaper than a new belt.
Or the down time of the bike.
Bill Murray
May 2, 2013 12:22 AM
OKIEVO
Dec 21, 2007 12:10 PM
clayman
Oct 15, 2006 03:08 PM
bluedog
Feb 23, 2006 12:15 PM
