VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
V-Rod Muscle - missing gears?
Old Oct 26, 2024 | 03:01 AM
eding's Avatar
eding
Stage I
Default V-Rod Muscle - missing gears?
If any of you V-Rod Muscle owners out there with forward controls miss a shift from time to time, it might be worth adjusting the gear lever rod. I found that if I adjusted the lever to the same angle as the brake pedal I stopped missing shifts altogether. I mustn't have been moving the lever quite far enough, and adjusting the position slightly was all that it was needed.
Enjoy that last of this sunny riding weather here in the UK, it won't last!
Old Oct 31, 2024 | 12:05 PM
Big Bear's Avatar
Big Bear
Thumbs up Missing a shift from time to time.
You are absolutely right, it is funny how a really small adjustment makes such a big difference as I found several years ago on my Muscle. When you unbolt the "Rose" joint at one end to adjust the rod, it is worth putting a good grease on the joint. This helps keep the changes smooth and keeps out water and corrosion. I reapply grease each autumn when applying ACF 50 (yes I have been out in our UK sunshine today and hope to ride throughout our autumn/winter here).
Big Bear
VRSC Models
Nov 10, 2014 06:51 AM
Redwingswin3
VRSC Models
Jun 20, 2012 10:19 AM
