VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Poorly running Vrod
Old Jun 3, 2025 | 01:26 PM
ROVBOY's Avatar
ROVBOY
Stage II
Default Poorly running Vrod
Hi there, whilst riding with the bike (NRS) running perfectly, suddenly it developed a misfire and now, starts but only runs briefly then misfires and stops. It will start but will only idle for a few seconds and dies. Any attempt to rev the engine will cause it to stall? Any suggestions as to what it could be? I'm thinking 1. voltage regulator, 2. fuel pump. Any suggestions gratefully received. Getting desperate!
Old Jun 4, 2025 | 06:14 AM
ThunderTruck's Avatar
ThunderTruck
A quick check to see if it's a fuel issue; hook a pressure gauge up to the Schrader valve. It should be very steady, if you see it swinging wildly the suction sock may be disintegrating or the line from the pump to the fuel filter may have cracked.
It's an easy check while looking for sources of the problem.
Good luck.
Old Jun 7, 2025 | 05:10 AM
ROVBOY's Avatar
ROVBOY
Stage II
Good luck.
Thank you, thats a big help and a good starting point.
NzScorp
General Topics/Tech Tips
Dec 30, 2022 08:32 AM
Bodean46
Dec 6, 2013 05:18 AM
Biped
VRSC Models
Jan 24, 2009 01:05 PM
HarleyGirl76
VRSC Models
24
Oct 30, 2007 08:10 PM
bodyman0
VRSC Models
Sep 27, 2006 01:54 AM
