VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Drive belt question
Old Feb 10, 2008 | 12:11 AM
HarleyGirl76's Avatar
HarleyGirl76
Default Drive belt question
OK, warning ahead of time, it's a stupid question. I was cleaning the bike up after a ride today and noticed that there is a lot of black rubberlike shavings on the rear wheel and on the belt guard. Is that normal, or does it need adjustment?
It was a great day for a ride today - 77 and sunny.
Lisa
Old Feb 10, 2008 | 09:35 AM
eazy's Avatar
eazy
Default RE: Drive belt question
Some--maybe, a lot--no. Where are the shavings coming from? (ribs of belt, sides, top) can you tell what's causing the issue? Simple tension adjustment may not solve your problem. How tight does it feel? (How far can you push the belt out of line at the center between the two pulley?)
Old Feb 10, 2008 | 09:42 AM
Vrod Mike's Avatar
Vrod Mike
First I would make sure where it's coming from. It may not even be the belt. Do a thorough inspection of the area to see where it's rubbing. Then like Eazy stated take a look at the belt. It should flex, but be stiff when doing so. Also, what side of the pulley is the belt resting on? Mine rides on the left side of the pulley and I've never seen any shavings from the belt.
Old Feb 10, 2008 | 12:10 PM
DesertSpeed's Avatar
DesertSpeed
Account Suspended
That's a new one on me. 17,000 miles and my belt still looks great. I have heard of oversize tires rubbing.
Old Feb 10, 2008 | 12:35 PM
eazy's Avatar
eazy
ORIGINAL: Vrod Mike
ORIGINAL: DesertSpeed
I was getting on to say the same thing. When I drop the ***-end all the way down the 200 would rub on the rear fender struts and create shavings. Took a grinder to make room on the struts. Did you do a lot of 2 up riding with a low shock setting? (1 or 2 on the stock shocks) This type of riding could be causing the tire to rub on the frame, even if it is the stock sized tire. You need to find out where the shavings are coming from.
Old Feb 10, 2008 | 05:02 PM
HarleyGirl76
I can't tell for sure whether it's tne belt or not. There's not a lot there, it just seemed like there shouldn't be any. I don't do two up riding and weigh 110 so it better not be my weight... I did just have some stupid saddlebags put on that may be part of the problem.
The belt seems very tight, not a lot of flex in it, but it looks like it's in really good condition. Thanks for the suggestions, I'll take a closer look and come back to you for help if I can't figure it out. You guys are great.
Lisa
Old Feb 11, 2008 | 10:45 AM
lakedrunk's Avatar
lakedrunk
ORIGINAL: HarleyGirl76
Lisa
Do you have a 200 tire? Look at your tire if there is any marks in it. You say you got saddlebags put on, maybe when mounting them either the mounting bracket or bolts or something are rubbing the tire.
Old Feb 12, 2008 | 12:42 PM
HarleyGirl76
You were right on - one of the bolts for the saddlebag frame on the left side of the bike was rubbing once in a while it looks like. As always thanks for your help with stupid questions.
Lisa
ORIGINAL: lakedrunk
Lisa
Old Feb 12, 2008 | 07:24 PM
DesertSpeed
Account Suspended
There ya go. Rubber shavings are almost never belt problems. If it had been the belt, you would also have handling issues from the rear tire being off center. (The tid-bit about the bags would have really helped with the diagnosis. )
aces&8s
EVO
30
Sep 3, 2018 07:52 PM
karamaxjoe
Oct 21, 2015 07:12 AM
mikeallenbrown
Aug 23, 2011 09:15 PM
Tanker2
Apr 12, 2009 06:49 AM
clayman
Oct 15, 2006 03:08 PM
